What I do not understand is that I have cleared the error several times already, and my ZWave integration has already started. So I am not sure why I keep seeing the error message.
If I click on Start, it tells me the issue has been resolved, yet the following day I see the same message. System Core Logs are empty as well.
I am running Z-Wave JS UI 3.23.0 and have just updated to home assistant OS HA Core 2025.3.2 (was previously on 2025.3.1).
You can’t run both add-ons at the same time. The warning is about the core Z-Wave JS add-on. Running both at the same time will result in one of them failing. From the info provided we don’t know which one you are actually using with HA. Check the Server URL in the integration settings panel. If it’s pointing to core, following the migration guide. If it’s pointing to the add-on, delete the core add-on.
Thanks! I didn’t realize that it was complaining about the core add-on. Had some confusion when I was first setting up ZWave integration an installed the core-addon before realizing that I only needed the JS addon. I guess I completely forgot to delete the Core one and it was still set to start at boot-up.
