Z-Wave JS to MQTT add-on not working after upgrade
Getting the following:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/00-banner.sh
 Add-on: Z-Wave JS to MQTT
 Fully configurable Z-Wave JS to MQTT gateway and control panel; based on Zwavejs2Mqtt
 Add-on version: 0.46.1
 You are running the latest version of this add-on.
 System: Home Assistant OS 8.5  (amd64 / qemux86-64)
 Home Assistant Core: 2022.9.0
 Home Assistant Supervisor: 2022.08.6
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/configuration.sh
cont-init: info: /etc/cont-init.d/configuration.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun nginx (no readiness notification)
services-up: info: copying legacy longrun zwavejs2mqtt (no readiness notification)
s6-rc: info: service legacy-services successfully started
[12:53:00] INFO: Starting the Z-Wave JS to MQTT...
/opt/node_modules/@zwave-js/cc/build/cc/SoundSwitchCC.js:91
                return this.setConfiguration(0x00 /
SyntaxError: Invalid or unexpected token
    at Object.compileFunction (node:vm:352:18)
    at wrapSafe (node:internal/modules/cjs/loader:1033:15)
    at Module._compile (node:internal/modules/cjs/loader:1069:27)
    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
    at Module.load (node:internal/modules/cjs/loader:981:32)
    at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    at Module.require (node:internal/modules/cjs/loader:1005:19)
    at require (node:internal/modules/cjs/helpers:102:18)
    at Object.<anonymous> (/opt/node_modules/@zwave-js/cc/src/cc/index.ts:442:1)
    at Module._compile (node:internal/modules/cjs/loader:1105:14)
[12:53:00] WARNING: zwavejs2mqtt crashed, halting add-on
s6-rc: info: service legacy-services: stopping
[12:53:00] INFO: zwavejs2mqtt stoped, restarting...
[12:53:00] INFO: NGinx stoped, restarting...
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped```
@rnvntr have you solve the problem? I have the same problem
fresh restart, unplugged the zwave adapter, put it on another port (USB 2.0), and it started working again.
