I have moved from using the original ZWave to the new Z-Wave JS Add-on (running Home Assistant OS).
I noticed that my Qubino Dimmers (ZMNHDD) now take noticeably longer to turn on or off. Looking at debug logs, shows that this is due to the dimmer transitioning through a series of intermediate values - i.e. ramping from the off-state to the on-state. See below:
2021-04-12 16:09:39 DEBUG (MainThread) [zwave_js_server] Publishing message:
{'command': 'node.set_value',
'messageId': 'xxxxxxxxxxxxxxxxxxxxxxxxxx98a96',
'nodeId': 31,
'value': 255,
'valueId': {'ccVersion': 3,
'commandClass': 38,
'commandClassName': 'Multilevel Switch',
'endpoint': 0,
'metadata': {'label': 'Target value',
'max': 99,
'min': 0,
'readable': True,
'type': 'number',
'writeable': True},
'property': 'targetValue',
'propertyName': 'targetValue',
'value': 0}}
2021-04-12 16:09:39 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"result","success":true,"messageId":"xxxxxxxxxxxxxxxxxxxxxxxxxx98a96","result":{"success":true}}', extra='')
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"node","event":"value updated","nodeId":31,"args":{"commandClassName":"Multilevel Switch","commandClass":38,"endpoint":0,"property":"currentValue","newValue":18,"prevValue":0,"propertyName":"currentValue"}}}', extra='')
2021-04-12 16:09:39 DEBUG (MainThread) [homeassistant.components.zwave_js.entity] [light.dimmer_spare_room] Value currentValue/None changed to: 18
2021-04-12 16:09:40 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"node","event":"value updated","nodeId":31,"args":{"commandClassName":"Multilevel Switch","commandClass":38,"endpoint":0,"property":"currentValue","newValue":27,"prevValue":18,"propertyName":"currentValue"}}}', extra='')
2021-04-12 16:09:40 DEBUG (MainThread) [homeassistant.components.zwave_js.entity] [light.dimmer_spare_room] Value currentValue/None changed to: 27
2021-04-12 16:09:41 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"node","event":"value updated","nodeId":31,"args":{"commandClassName":"Multilevel Switch","commandClass":38,"endpoint":0,"property":"currentValue","newValue":63,"prevValue":27,"propertyName":"currentValue"}}}', extra='')
2021-04-12 16:09:41 DEBUG (MainThread) [homeassistant.components.zwave_js.entity] [light.dimmer_spare_room] Value currentValue/None changed to: 63
2021-04-12 16:09:42 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"node","event":"value updated","nodeId":31,"args":{"commandClassName":"Multilevel Switch","commandClass":38,"endpoint":0,"property":"currentValue","newValue":90,"prevValue":63,"propertyName":"currentValue"}}}', extra='')
2021-04-12 16:09:42 DEBUG (MainThread) [homeassistant.components.zwave_js.entity] [light.dimmer_spare_room] Value currentValue/None changed to: 90
2021-04-12 16:09:44 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"node","event":"value updated","nodeId":31,"args":{"commandClassName":"Multilevel Switch","commandClass":38,"endpoint":0,"property":"currentValue","newValue":99,"prevValue":90,"propertyName":"currentValue"}}}', extra='')
2021-04-12 16:09:44 DEBUG (MainThread) [homeassistant.components.zwave_js.entity] [light.dimmer_spare_room] Value currentValue/None changed to: 99
Any idea how I can get the dimmer to turn on immediately (i.e. directly from 0 to 99)?
