This is what I see each time I try to restart the add-on.
Any idea ?
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[14:06:57] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[14:07:05] INFO: Virtual Machine not detected, enabling soft-reset
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[14:07:10] INFO: Successfully send discovery information to Home Assistant.
2023-04-27T21:07:19.714Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2023-04-27T21:07:19.735Z DRIVER version 10.16.0
2023-04-27T21:07:19.740Z DRIVER
2023-04-27T21:07:21.114Z CONFIG version 10.16.0
2023-04-27T21:07:26.104Z CNTRLR querying controller IDs...
2023-04-27T21:07:28.364Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-04-27T21:07:29.486Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-04-27T21:07:31.653Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
from the controller (ZW0200)
at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Drive
r.ts:4199:23)
at ZWaveController.identify (/usr/src/node_modules/zwave-js/src/lib/contro
ller/Controller.ts:930:33)
at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src
/lib/driver/Driver.ts:1292:26)
at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Dr
iver.ts:1098:16)
Error in driver ZWaveError: Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:4199:23)
at ZWaveController.identify (/usr/src/node_modules/zwave-js/src/lib/controller/Controller.ts:930:33)
at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1292:26)
at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1098:16) (ZW0100)
at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1115:6)
at processTicksAndRejections (node:internal/process/task_queues:95:5) {
code: 100,
context: undefined,
transactionSource: undefined
Shutting down
