I’m configuring the z-wave Aeotec TriSensor for light level control and I’m not sure how the Reports are handled in HA. Any help form experienced users would be much appreciated.
It seems that Parameter 24 “Light automatic report based on time” sends the light level at timed intervals (default 3600) to sensor.luminance as this value is updating every 1 hour in HA.
However there is Parameter 22 “Light Threshold Report” which looks like it is supposed to send a report whenever the lux measurement changes by a certain amount (default 100). If I artificially change the lux near the sensor with a lamp I do not see the sensor.luminance value updating. It only updates on the timed interval. The same seems to be applicable to the temperature measurements.
I want to poll the lux level and temperature frequently (maybe every minute) to enable a good resolution of data for controlling lights and zoned heating. Currently looks like I need to increase the Timed report to every minute which will effect the sensor battery life, this feels wrong if it is possible to handle using the Threshold reports.
Is anyone able to advise how to use of these sensors effectively?
Are the Threshold reports and Timed reports fundamentally different?
Is the sensor not actually generating the Threshold report or it just being ignored by HA/controller?
*Bonus points if you can explain the last statement in this parameter description:
“This parameter is configured the time interval for light sensor report. This value is larger, the battery life is longer. And the light intensity changed is not obvious.”
