After migration to Zwave JS I can’t control my floors:
https://devices.zwave-js.io/?jumpTo=0x0115:0x0024:0x0001:0.0
And no OFF button in card after migration:
Before migration config:
<Node id="4" name="" location="" basic="4" generic="8" specific="6" type="General Thermostat V2" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="115" name="Z-Wave.Me">
<Product type="24" id="1" name="Floor Thermostat" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" innif="true" mapping="64">
<Instance index="1" />
</CommandClass>
<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="4" innif="true">
<Value type="decimal" genre="user" instance="1" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="10" min="0" max="0" value="25.9" />
<Value type="decimal" genre="user" instance="1" index="9" label="Barometric Pressure" units="inHg" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="25.1" />
<Value type="decimal" genre="user" instance="1" index="33" label="Time" units="s" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="844.3" />
</CommandClass>
<CommandClass id="64" name="COMMAND_CLASS_THERMOSTAT_MODE" version="2" innif="true">
<Value type="list" genre="user" instance="1" index="0" label="Mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="10" min="0" max="0" vindex="0" size="1">
<Item label="Off" value="0" />
<Item label="Heat" value="1" />
<Item label="Furnace" value="7" />
<Item label="Heat Econ" value="11" />
</Value>
<SupportedModes>
<Mode index="0" label="Off" />
<Mode index="1" label="Heat" />
<Mode index="7" label="Furnace" />
<Mode index="11" label="Heat Econ" />
</SupportedModes>
</CommandClass>
<CommandClass id="67" name="COMMAND_CLASS_THERMOSTAT_SETPOINT" version="2" request_flags="2" innif="true" base="1" typeInterpretation="B">
<Value type="decimal" genre="user" instance="1" index="1" label="Heating 1" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="30.0" />
<Value type="decimal" genre="user" instance="1" index="2" label="Cooling 1" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
<Value type="decimal" genre="user" instance="1" index="4" label="Unused 4" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
<Value type="decimal" genre="user" instance="1" index="7" label="Furnace" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="35.0" />
<Value type="decimal" genre="user" instance="1" index="8" label="Dry Air" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
<Value type="decimal" genre="user" instance="1" index="11" label="Heat Econ" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="35.0" />
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="117" name="COMMAND_CLASS_PROTECTION" version="1" request_flags="4" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Unprotected" value="0" />
<Item label="Protection by Sequence" value="1" />
<Item label="No Operation Possible" value="2" />
</Value>
</CommandClass>
<CommandClass id="119" name="COMMAND_CLASS_NODE_NAMING" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
<Associations num_groups="1">
<Group index="1" max_associations="10" label="Group 1" auto="true">
<Node id="1" />
<Node id="4" />
</Group>
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3.42" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.01" />
</CommandClass>
</CommandClasses>
</Node>
Please, help! How fix?
