Z wave micro smart switch
Hi all,
Only me again looking for some more advice :wink:
In my hallway I have a normal light switches downstairs and upstairs that controller the same light. All my other lights in the house are controlled by hue and I need to be able to automate these aswell but cost to much as they are gu10 bulbs.
my question is do I need to purchase 2 of these for each switch or will one work just fine?
Is this even the right thing? A dimmer might be good on it also for motion night light but I don’t watch actual dimmer switches installed.
Many thanks
Mike
Here is what I used for my three way switch:
https://www.amazon.com/GE-Wireless-Lighting-Control-Three-Way/dp/B018A46V82/ref=sr_1_1?ie=UTF8&qid=1466627783&sr=8-1&keywords=ge+zwave+three+way
Not positive if the micro switch would work for three-way, looks like it is designed to control a single switch
Cheers buddy am in the UK so not sure these will work for me. I should of said this earlier my apologises.
Thanks for your input though mate
The micro switch could work for your situation. Take a look at Aeotecs wiring schematics for examples. There are a few for 3 way both with live wiring or without on the manual switch side.
http://aeotec.com/support/1219-micro-switch-wiring-schematics.html
Your configuration will really will depend on how your existing 3-way switch is currently wired and where the power enters the circuit (into the light or into a switch) and if there is an actual neutral you can use (and not a neutral, being used as a traveler). They can be confusing so if you don’t know what your looking at, it is probably best to get an electrician to help you out.
Thank’s buddy I will look into this more. I actually have a 2 way switch I need to double check if a neutral cable in installed.
