After I started with HA I found out it is a usefull program for a lot of things.
N ow I am trieing too get my z-wave stuff in it.
I do have a large number of devices (somewhat over 100). Because I read on several places that the maximum for most controllers is around 50, I do have 2 controller. A aeotec zwave stick version 5 and 1 version 7.
I want to integrate both in HA.
I don’t know in the first place if that is possible.
But I read in a topic that zwave js UI could be helfull with this.
So I am triing to install that.
But when I start up I get the next log:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Z-Wave JS UI
Fully configurable Z-Wave JS gateway and control panel
Add-on version: 1.6.2
You are running the latest version of this add-on.
System: Home Assistant OS 9.5 (amd64 / qemux86-64)
Home Assistant Core: 2023.1.7
Home Assistant Supervisor: 2023.01.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-zwave-js-ui: starting
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-nginx successfully started
s6-rc: info: service init-zwave-js-ui successfully started
s6-rc: info: service zwave-js-ui: starting
s6-rc: info: service zwave-js-ui successfully started
s6-rc: info: service discovery: starting
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
[13:05:01] INFO: Starting the Z-Wave JS UI...
./run: line 16: ./discovery: No such file or directory
So I added /discovery but still the same error.
Can anyone help me to get this working?
