Not sure what’s going on but updated like an hour ago to z-wave js addon 0.10.0 and now some nodes are not showing as online and even the ones showing up are not able to be controlled from home assistant.
The addon logs start up normally for a while then start spamming like this
2025-02-13T01:15:47.148Z CNTRLR Serial API restarted unexpectedly.
2025-02-13T01:15:47.148Z CNTRLR Currently active command will be retried...
2025-02-13T01:15:47.148Z CNTRLR Starting hardware watchdog...
2025-02-13T01:15:47.151Z CNTRLR Switching serial API to 16-bit node IDs...
2025-02-13T01:15:47.167Z CNTRLR Switching to 16-bit node IDs successful
2025-02-13T01:15:48.396Z CNTRLR Serial API restarted unexpectedly.
2025-02-13T01:15:48.396Z CNTRLR Currently active command will be retried...
2025-02-13T01:15:48.396Z CNTRLR Starting hardware watchdog...
2025-02-13T01:15:48.399Z CNTRLR Switching serial API to 16-bit node IDs...
2025-02-13T01:15:48.415Z CNTRLR Switching to 16-bit node IDs successful
2025-02-13T01:15:49.644Z CNTRLR Serial API restarted unexpectedly.
2025-02-13T01:15:49.644Z CNTRLR Currently active command will be retried...
2025-02-13T01:15:49.645Z CNTRLR Starting hardware watchdog...
2025-02-13T01:15:49.648Z CNTRLR Switching serial API to 16-bit node IDs...
2025-02-13T01:15:49.665Z CNTRLR Switching to 16-bit node IDs successful
2025-02-13T01:15:50.894Z CNTRLR Serial API restarted unexpectedly.
2025-02-13T01:15:50.894Z CNTRLR Currently active command will be retried...
2025-02-13T01:15:50.894Z CNTRLR Starting hardware watchdog...
2025-02-13T01:15:50.898Z CNTRLR Switching serial API to 16-bit node IDs...
2025-02-13T01:15:50.914Z CNTRLR Switching to 16-bit node IDs successful
I completely restarted my home assistant yellow and then I restored the addon to 0.9.0 from yesterday’s backup but that hasn’t fixed the issue.
Also seeing the occasional log like this
2025-02-13T01:16:37.111Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2025-02-13T01:16:37.113Z CNTRLR [Node 5791] is unknown - discarding received command...
Controller is a Zooz ZST10 with firmware 7.18.3
Been running it for maybe 2 years now and never seen this issue.
