Im new to this. Ive been looking through several posts here and I cant seem to find what Im doing wrong. I have HA green. I have installed the Zwave JS add on. My Zooz 7 stick shows in the path for the controller. Add on is running and everything looks good, but I cant pair any zwave devices. I cant figure out what im missing.
Factory reset device and try again. Sometimes devices improperly pair or were previously paired so they don’t pair.
You are sure zwavejs is running?
It is showing that zwavejs is running. I don’t see any errors in the log and I can ping my z-stick successfully. I will try that. Thank you. I need to do some more investigating.
Update: My Fibaro z-wave implant switches were made in Germany so they operate on European frequency and I had my z-stick set to US. Switched it to European and problem solved. Not sure why it took me so long to figure this out. Hopefully this might help someone else out.
