Z wave pairing
Hi, I’m moving from VERA to HA and I got to the stage of adding aeotec z-stick 7, it took a while and I managed to add it and it is recognized in HA, the problem is that I can’t pair ZWAVE accessories,
I tried with an extension cable and without an extension cable, tried a FIBARO module and a COOLCAM socket to rule out a problem with a specific product.
I’ve tried dozens of attempts without success and I don’t know what causes the problem?
Z-Wave JS UI is installed, I understood that this is the preferred way.
I would appreciate your advice
Make sure if the device supports S2 security, you’re adding the S2 security pin. Bring a device next to the controller and try to add it when it is close, see if that works.
Do a full reset first for each module you want to pair.
I had similar issues with a number of Fibaro devices, resetting the device helped.
