I have a small Z-Wave Network with the Aeotec Stick and Fibaro Devices.
Now I want to control my garage door system with Z-Wave but I am struggeling with finding a device for that request.
First I thought I could use a Fibaro Switch, but they do not have a potential free contact.
Then I found the universal sensor, but for this one I need a seperate power supply.
I have PAN06-1b from philio for couple lights. It is potential free. But both relays are in same potential, whatever is connected to “com”. See here
But did I understand you correctly, you don’t have L and N to power the switch? That should be easily arranged in garage if you have already some system to open the door.
How do you set it up to trigger yoru garage door with home assistant?
I used to have this setup and working with SmartThings but now I can’t figure out how to translate that once I have it in HomeAssistant.
