I’m trying to replace my last x10 device which is a dimmer switch on my pool light. The light is 120v 500w incandescent. The existing x10 dimmer is immediately downstream from a GFCI. I tried installing a GE z-wave dimmer (14296), but it immediately trips the GFCI. Is there a z-wave dimmer switch that will work downstream from the required GFCI? Other ideas?
You are in North America? This Z-Wave vendor may know. They make Zooz & sell others too
Try emailing [email protected]
Try Zwave switch that doesn’t require neutral
Also, problem may have been dimmer switch inline with gfci
I actually planned to replace my pool light switch with the switch version of GE. If I get something that works I’ll let you know
