Suddenly my z-wave is not working on my Hass.io setup.
I got the following error in the log;
2017-10-20 18:19:43 ERROR (MainThread) [homeassistant.setup] Error during setup of component zwave
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 194, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/zwave/__init__.py", line 244, in setup
from pydispatch import dispatcher
File "/usr/lib/python3.6/site-packages/pydispatch/dispatcher.py", line 29, in <module>
from pydispatch import saferef, robustapply, errors
ImportError: cannot import name 'errors'
2017-10-20 18:19:58 WARNING (SyncWorker_11) [netdisco.ssdp] Error fetching description at http://192.168.1.7:49130/devdesc.xml
2017-10-20 18:20:01 ERROR (SyncWorker_13) [homeassistant.util.yaml] unacceptable character #x0000: special characters are not allowed
in "/usr/lib/python3.6/site-packages/homeassistant/components/media_player/services.yaml", position 0
2017-10-20 18:20:02 ERROR (MainThread) [homeassistant.setup] Error during setup of component media_player
File "/usr/lib/python3.6/site-packages/homeassistant/util/yaml.py", line 70, in load_yaml
return yaml.load(conf_file, Loader=SafeLineLoader) or OrderedDict()
File "/usr/lib/python3.6/site-packages/yaml/__init__.py", line 70, in load
loader = Loader(stream)
File "/usr/lib/python3.6/site-packages/yaml/loader.py", line 24, in __init__
Reader.__init__(self, stream)
File "/usr/lib/python3.6/site-packages/yaml/reader.py", line 85, in __init__
self.determine_encoding()
File "/usr/lib/python3.6/site-packages/yaml/reader.py", line 135, in determine_encoding
self.update(1)
File "/usr/lib/python3.6/site-packages/yaml/reader.py", line 169, in update
self.check_printable(data)
File "/usr/lib/python3.6/site-packages/yaml/reader.py", line 144, in check_printable
'unicode', "special characters are not allowed")
yaml.reader.ReaderError: unacceptable character #x0000: special characters are not allowed
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 191, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File "/usr/lib/python3.6/site-packages/homeassistant/components/media_player/__init__.py", line 377, in async_setup
os.path.dirname(__file__), 'services.yaml'))
future.result()
File "/usr/lib/python3.6/site-packages/homeassistant/config.py", line 289, in load_yaml_config_file
conf_dict = load_yaml(config_path)
File "/usr/lib/python3.6/site-packages/homeassistant/util/yaml.py", line 73, in load_yaml
raise HomeAssistantError(exc)
homeassistant.exceptions.HomeAssistantError: unacceptable character #x0000: special characters are not allowed
Anybody who knows what this is?
