Whenever I change the state of my zen76 switch, it immediately reports that it’s state is off.
Kind of confusing but:
So if it is off, and I turn it on, it turns on (and the state changes to on for a second) but then it reports the state is off, so it is on but HA thinks it is off
Then if it’s on, the current state in HA is off and I have to hit on again to turn it off. It remains off but the state then flips back from on to off.
Any solution? Makes it pretty impossible to automate because it always reports off (except for half a second after I change the state).
My first thought was a messed-up switch setting. First check to see if theres a new firmware available, as it may fix a known bug. Then I’d try excluding the node, performing a full factory reset, and adding it back again. Exclude / include by tapping the top button 3 times; to reset, follow this procedure.
