Z-Wave unknown Nodes
I’m using the ZWave_js addon and the integration with a aeontec z-wave stick. In my network there are two Heating thermostats and nothing else but already on installation there are 5 nodes showing up (one is the controller). Can you help me what they are?
Regards
1 node is controller
2 node are thermostat
2 unknown should be found in the devices list of the integration. Did you previously pair devices, reset and pair again. Old pairing will still show as paired but failed
Thank you for your response. Tried to reset the network by deleting addon and integration and since that didn’t help, i tried to reset by stick button but the nodes are there anyway. How can I get them out of the network. So I can connect the two thermostats from scratch?
Delete/Remove dead Node is enough. They are showing as dead correct?
Deleting addon and integration won’t work. Nodes exist in the stick. Also I think data for integration remain so when add it again it just come back (not sure about that)
I
