Z-Wave wrong setup? Cant control devices
Hi, i installed on a fresh Raspian (PI3) Home Assistant with the All-In-One-Package. I use a simple U-Wave USB Stick.
Then i add in the root@raspberrypi:/home/homeassistant/.homeassistant/configuration.yaml on the end of the file:
zwave:
  usb_path: /dev/ttyACM0
After that, i stopped the HA with sudo systemctl restart home-assistant.service and go to the OpenZWaveController Webinterface. Select my dev/ttyACM0 and Add my DANALOCK. Works good so far. Cant find out how to control the Danalock in the OpenZWaveController, but maybe its not possible?
After i started the HA new with sudo systemctl restart home-assistant.service i see something new in the “States” Site.
Polycontrol Danalock V2 125 BTZE locked
But when i switch on the lock, nothing happens.
I found on the INFO side this:
17-02-02 14:27:51 WARNING (Thread-10) [homeassistant.components.zwave] zwave not ready after 30 seconds, continuing anyway
Did i made something wrong on the setup?
You can ignore the zwave not ready message. That’s pretty standard on startup.
I believe the lock is a secure Zwave device, so it requires a network key to be setup before adding the lock, so I would go back into zwave control panel, then remove the lock, set up the network key and re-add the lock.
