im looking into implementing a 2 way switch set up without the need of home assistant (direct bind). Both switches should independently turn on or off the light.
The Problem is that, each switch sends presumably a on or off command to the group. Now if the group has already the state on from the first switch, the received on command from the second switch is not turned into off. Which results into having rocking the switch again.
Is there something i have overlooked?
My set up: 2 Philips hue wall modules, 1 Sonoff zbminir2 relais.
no, i cannot add both switches to the light group „Korridorlicht_group“, i already tried but received an error. according to the documentation in Philips 929003017102 control via MQTT | Zigbee2MQTT this is expected
I’m facing the same issue as described here with two Hue Wall Switches and one lamp. The binding works, but the switches don’t toggle the lamp correctly unless I toggle them twice.
I figured out a partial solution to this with HA stepping in to toggle the switch in case the direct approach has not worked in 100ms delay. its not perfect, but at least if HA is not available (during restart for example) wife can still use the switches…
Hope it helps you in the meanwhile until someone can address that.
Basically, on click it saves the current light state, then compares after 100ms if the toggle happened. if not HA will toggle it.
alias: MQTT Helper2
description: >-
For this purpose, every actuator must have a binding with a
lamp. If the actuator does not trigger directly when a switch is pressed, HA
assists by toggling the lamp. This eliminates the need for pressing the switch
again for direct binding.
triggers:
- domain: mqtt
device_id: 30081cf42eb5fb5669e5808ff0952b7f
type: action
subtype: left_press
trigger: device
alias: Korridorlicht OG Aktor 1
- domain: mqtt
device_id: faf7dde35053b6f95d5daae8c7e59964
type: action
subtype: left_press
trigger: device
alias: Korridorlicht OG Aktor 2
conditions: []
actions:
- variables:
korridorlicht_zustand: "{{ states('light.korridorlicht') }}"
- delay:
milliseconds: 100
enabled: true
- choose:
- conditions:
- condition: and
conditions:
- condition: template
value_template: "{{ states('light.korridorlicht') == korridorlicht_zustand }}"
- condition: trigger
id:
- OG_AK2
- OG_AK1
sequence:
- target:
entity_id: light.korridorlicht
action: light.toggle
data: {}
mode: single
