Z2M configuration for Sonoff ZBplus dongle E
Hi
I just bought this new device and it does not seem to work well with Z2M. When starting it, i have this error:
[16:19:00] INFO: Preparing to start...
[16:19:01] INFO: Socat not enabled
[16:19:02] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2025-10-20 16:19:07] info: 	z2m: Logging to console, file (filename: log.log)
[2025-10-20 16:19:07] info: 	z2m: Starting Zigbee2MQTT version 2.6.2 (commit #unknown)
[2025-10-20 16:19:07] info: 	z2m: Starting zigbee-herdsman (6.1.5)
[2025-10-20 16:19:08] info: 	zh:ember: Using default stack config.
[2025-10-20 16:19:08] info: 	zh:ember: ======== Ember Adapter Starting ========
[2025-10-20 16:19:08] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2025-10-20 16:19:08] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-10-20 16:19:08] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2025-10-20 16:19:08] info: 	zh:ember:uart:ash: Serial port opened
[2025-10-20 16:19:08] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-10-20 16:19:13] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-10-20 16:19:13] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-10-20 16:19:18] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-10-20 16:19:18] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-10-20 16:19:23] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-10-20 16:19:23] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-10-20 16:19:28] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-10-20 16:19:28] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-10-20 16:19:33] error: 	z2m: Error while starting zigbee-herdsman
[2025-10-20 16:19:33] error: 	z2m: Failed to start zigbee-herdsman
[2025-10-20 16:19:33] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-10-20 16:19:33] error: 	z2m: Exiting...
[2025-10-20 16:19:33] error: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:665:19)
    at EmberAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1547:24)
    at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
    at Zigbee.start (/app/lib/zigbee.ts:67:27)
    at Controller.start (/app/lib/controller.ts:101:13)
    at start (/app/index.js:149:5)
I have tried both ember and ezsp adapters, and none of them seem to be working
Any idea how can i make it work?
Do you have the Zigbee Home Automation (ZHA) integration installed? If you do, uninstall it because you cannot have ZHA and Z2M use the same coordinator.
If you don’t have ZHA installed, review the troubleshooting suggestions in the link provided in one of the error messages. Look for suggestions related to HOST_FATAL_ERROR.
Hi
No, no ZHA.
I found out what was the problem. coordinator_backup.json. For any reason that file was creating issues. I renamed it and everything works fine!
You said you “bought this new device”. Did you buy a new coordinator to replace an older one? If so, what brand and model was the older one? Same or different from the newer one?
coordinator_backup.json is likely to contain configuration information for the older coordinator.
Hi
Yes, its a new device to replace the previous one, Sonoff ZB Plus. I should have mentioned that, sorry
