Z2m doesnt start (MS 11, Virtualbox, PMG24, noZHA, extension cable,)
[07:52:10] INFO: Preparing to start…
[07:52:10] INFO: Socat not enabled
[07:52:11] INFO: Starting Zigbee2MQTT…
Starting Zigbee2MQTT without watchdog.
[2026-03-18 07:52:15] info: z2m: Logging to console, file (filename: log.log)
[2026-03-18 07:52:15] info: z2m: Starting Zigbee2MQTT version 2.9.1 (commit #unknown)
[2026-03-18 07:52:16] info: z2m: Starting zigbee-herdsman (9.0.9)
[2026-03-18 07:52:16] info: zh:ember: Using default stack config.
[2026-03-18 07:52:16] info: zh:ember: ======== Ember Adapter Starting ========
[2026-03-18 07:52:16] info: zh:ember:ezsp: ======== EZSP starting ========
[2026-03-18 07:52:16] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-03-18 07:52:16] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2026-03-18 07:52:16] info: zh:ember:uart:ash: Serial port opened
[2026-03-18 07:52:16] info: zh:ember:uart:ash: ======== ASH starting ========
[2026-03-18 07:52:21] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-03-18 07:52:21] info: zh:ember:uart:ash: ======== ASH starting ========
[2026-03-18 07:52:26] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-03-18 07:52:26] info: zh:ember:uart:ash: ======== ASH starting ========
[2026-03-18 07:52:31] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-03-18 07:52:31] info: zh:ember:uart:ash: ======== ASH starting ========
[2026-03-18 07:52:36] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-03-18 07:52:36] info: zh:ember:uart:ash: ======== ASH starting ========
[2026-03-18 07:52:42] error: z2m: Error while starting zigbee-herdsman
[2026-03-18 07:52:42] error: z2m: Failed to start zigbee-herdsman
[2026-03-18 07:52:42] error: z2m: Check Zigbee2MQTT fails to start/crashes runtime | Zigbee2MQTT for possible solutions
[2026-03-18 07:52:42] error: z2m: Exiting…
[2026-03-18 07:52:42] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:666:19)
at EmberAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1538:24)
at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:145:29)
at Zigbee.start (/app/lib/zigbee.ts:70:27)
at Controller.start (/app/lib/controller.ts:111:29)
at start (/app/index.js:156:5)
Answer or solution welcome!
Has it ever worked?
What adapter are you using?
yes two Sonoff it found, but know cant do it
using a Dongle PMG24 (Sonoff)
a presence sensor and a switch (both Sonoff) it found, but not a single more, as hard as I tried… but now not even that
