Z2M error touchlink
Hi I have a problem on z2m that concerns the touchlink. When it tries to search for a new device, I get this error that does not let me insert new devices:
warning 2025-01-16 17:27:56zh:controller:touchlink: Scan request failed or was not answered: ‘Error: Timeout - undefined - 254 - undefined - 4096 - 1 after 500ms’ I attach my configuration on home assistant to understand if something is wrong. I own a sonoff dongle plus
Configuration.yaml
devices:
  • devices.yaml
    groups:
  • groups.yaml
    homeassistant:
    enabled: true
    mqtt:
    base_topic: zigbee2mqtt
    server: mqtt://core-mosquitto
    user: xxxxx
    password: xxxxxxxxx
    keepalive: 60
    reject_unauthorized: true
    version: 4
    serial:
    port: >-
    /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_babb4f923693eb11925a214f3d98b6d1-if00-port0
    adapter: zstack
    advanced:
    log_level: warning
    pan_id: 6754
    channel: 11
    network_key:
    • 1
    • 3
    • 5
    • 7
    • 9
    • 11
    • 13
    • 15
    • 0
    • 2
    • 4
    • 6
    • 8
    • 10
    • 12
    • 13
      homeassistant_legacy_entity_attributes: false
      homeassistant_legacy_triggers: false
      legacy_api: false
      legacy_availability_payload: false
      device_options:
      legacy: false
      blocklist:
      passlist:
      queue: {}
      frontend:
      port: 8099
      availability:
      enabled: false
      ota:
      update_check_interval: 1440
      version: 4
config z2m
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
mqtt:
user: zzzzz
password: zzzzz
serial:
port: >-
baudrate: 115200
adapter: zstack
disable_led: false
advanced:
transmit_power: 20
