Hello everyone,
I’m having issues with a Zigbee2Mqtt group not truning off. It does turn on, but nothing happens when I ask it to turn off.
Here is the configuration on Z2M side:
groups:
'1':
friendly_name: kitchen_sink
retain: false
transition: 0
optimistic: true
devices:
- '0x00124b00226d5610'
- '0x00124b00226d5a1c'
Here is the configuration on HA side:
light:
- platform: mqtt
schema: json
command_topic: "zigbee2mqtt/kitchen_sink/set"
state_topic: "zigbee2mqtt/kitchen_sink"
color_temp: true
brightness: true
rgb: true
When I trigger the switch on, the logs on Z2M show this :
Zigbee2MQTT:info 2021-02-13 23:26:23: MQTT publish: topic 'zigbee2mqtt/0x00124b00226d5610', payload '{"brightness":254,"color":{"x":0.313059507478705,"y":0.323172994053855},"color_temp":153,"linkquality":89,"state":"ON"}'
Zigbee2MQTT:info 2021-02-13 23:26:23: MQTT publish: topic 'zigbee2mqtt/kitchen_sink', payload '{"brightness":254,"color":{"x":0.313059507478705,"y":0.323172994053855},"color_temp":153,"state":"ON"}'
Zigbee2MQTT:info 2021-02-13 23:26:23: MQTT publish: topic 'zigbee2mqtt/0x00124b00226d5a1c', payload '{"brightness":254,"color":{"x":0.313059507478705,"y":0.323172994053855},"color_temp":153,"linkquality":89,"state":"ON"}'
When I switch it off it’s identical (except the state obviously) but the bulbs remains physically ON.
Zigbee2MQTT:info 2021-02-13 23:28:03: MQTT publish: topic 'zigbee2mqtt/0x00124b00226d5610', payload '{"brightness":254,"color":{"x":0.313059507478705,"y":0.323172994053855},"color_temp":153,"linkquality":89,"state":"OFF"}'
Zigbee2MQTT:info 2021-02-13 23:28:03: MQTT publish: topic 'zigbee2mqtt/kitchen_sink', payload '{"brightness":254,"color":{"x":0.313059507478705,"y":0.323172994053855},"color_temp":153,"state":"OFF"}'
Zigbee2MQTT:info 2021-02-13 23:28:03: MQTT publish: topic 'zigbee2mqtt/0x00124b00226d5a1c', payload '{"brightness":254,"color":{"x":0.313059507478705,"y":0.323172994053855},"color_temp":153,"linkquality":89,"state":"OFF"}'
Has anybody experienced that or played with it?
Thanks in advance if anyone wants to pitch in
Christian
