Z2M pairing w/o connected lines?
hi,
I am little frustraded…
I updated my Conbee3 stick on windows and had afterwards some issues with the connections.
So I decided to delete all devices (50!) and add them completly new…
I started with the powered devices and then added some battery ones…
There are some troubles while pairing which I dont understand.
And if I now show the map it looks like crap:
Can somebody maybe explain what I am missing or what I can do to fix this issues?
some logs from the z2m addon:
[2025-01-29 18:17:20] error: 	z2m: EventBus error 'HomeAssistant/publishEntityState': Cannot read properties of undefined (reading 'isDevice')
[2025-01-29 18:24:45] error: 	z2m: Failed to configure '0x54ef441000c4bca8', attempt 1 (Error: ZCL command 0x54ef441000c4bca8/1 manuSpecificLumi.read([0], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"manufacturerCode":4447,"writeUndiv":false}) failed (no response received (28) Error: waiting for response TIMEOUT)
    at DeconzAdapter.sendZclFrameToEndpoint (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:475:19)
    at Request.send (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:82:20)
    at Endpoint.sendRequest (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:324:20)
    at Endpoint.zclCommand (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:949:28)
    at Endpoint.read (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:445:29)
    at configure (/app/node_modules/.pnpm/[email protected]/node_modules/src/devices/lumi.ts:3550:13)
    at Object.configure (/app/node_modules/.pnpm/[email protected]/node_modules/src/index.ts:257:21)
    at Configure.configure (/app/lib/extension/configure.ts:124:13)
    at EventEmitter.wrappedCallback (/app/lib/eventBus.ts:204:17))
[2025-01-29 18:28:32] error: 	z2m: Publish 'set' 'detection_interval' to '0x54ef441000cc99e5' failed: 'RangeError [ERR_OUT_OF_RANGE]: ZCL command 0x54ef441000cc99e5/1 manuSpecificLumi.write({"258":{"value":[5498],"type":32}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"manufacturerCode":4447,"writeUndiv":false}) failed (The value of "value" is out of range. It must be >= 0 and <= 255. Received 5498)'
[2025-01-29 18:36:01] error: 	z2m: Failed to execute LQI for 'Spülmaschine'
[2025-01-29 19:04:20] error: 	zh:controller: Interview failed for '0x00158d00028d3fa5 with error 'Error: DatabaseEntry with ID '29' does not exist'
[2025-01-29 19:13:55] error: 	zh:controller: Interview failed for '0x00158d000678e40a with error 'Error: Interview failed because can not get node descriptor ('0x00158d000678e40a')'
[2025-01-29 19:13:55] error: 	z2m: Failed to interview '0x00158d000678e40a', device has not successfully been paired
[2025-01-29 19:26:06] error: 	z2m: Failed to execute LQI for 'Repeater TV Board'
[2025-01-29 19:29:19] error: 	z2m: Failed to execute LQI for 'Xbox'
[2025-01-29 19:29:57] error: 	zh:controller: Interview failed for '0x00158d00067d9610 with error 'Error: Interview failed because can not get node descriptor ('0x00158d00067d9610')'
[2025-01-29 19:29:57] error: 	z2m: Failed to interview '0x00158d00067d9610', device has not successfully been paired
[2025-01-29 19:32:39] error: 	z2m: Failed to execute LQI for '0x00158d000678e40a'
[2025-01-29 19:34:45] error: 	z2m: Failed to execute LQI for '0x00158d00067d9610'
[2025-01-29 19:39:12] warning: 	z2m: Failed to ping 'Mikrowelle' (attempt 1/2, ZCL command 0x7cb03eaa0a0ae9e5/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (216) Error: waiting for response TIMEOUT))
[2025-01-29 19:43:37] warning: 	z2m: Failed to ping 'Schreibtisch Maike' (attempt 1/2, ZCL command 0x7cb03eaa0a09cbc8/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (224) Error: waiting for response TIMEOUT))
[2025-01-29 19:49:27] warning: 	z2m: Failed to ping 'Mikrowelle' (attempt 1/2, ZCL command 0x7cb03eaa0a0ae9e5/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (240) Error: waiting for response TIMEOUT))
[2025-01-29 19:54:52] error: 	zh:controller: Interview failed for '0x00158d00067d9643 with error 'Error: Interview failed because can not get node descriptor ('0x00158d00067d9643')'
[2025-01-29 19:54:52] error: 	z2m: Failed to interview '0x00158d00067d9643', device has not successfully been paired
[2025-01-29 20:08:52] warning: 	z2m: Failed to ping 'Mikrowelle' (attempt 1/2, ZCL command 0x7cb03eaa0a0ae9e5/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (23) Error: waiting for response TIMEOUT))
[2025-01-29 20:28:19] warning: 	z2m: Failed to ping 'Repeater Bad' (attempt 1/2, ZCL command 0x7cb03eaa0a0c544b/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (62) Error: waiting for response TIMEOUT))
[2025-01-29 20:40:41] error: 	zh:controller: Interview failed for '0xa4c1383f99a8fde8 with error 'Error: waiting for response TIMEOUT'
[2025-01-29 20:40:41] error: 	z2m: Failed to interview '0xa4c1383f99a8fde8', device has not successfully been paired
[2025-01-29 20:48:34] warning: 	z2m: Failed to ping 'Repeater Bad' (attempt 1/2, ZCL command 0x7cb03eaa0a0c544b/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (106) Error: waiting for response TIMEOUT))
[2025-01-29 21:02:32] error: 	z2m: Failed to execute LQI for 'Repeater Bad'
[2025-01-29 21:09:48] error: 	z2m: Publish 'set' 'state' to 'Mikrowelle' failed: 'Error: ZCL command 0x7cb03eaa0a0ae9e5/3 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (199) Error: waiting for response TIMEOUT)'
[2025-01-29 21:09:57] error: 	z2m: Publish 'set' 'state' to 'Repeater Bad' failed: 'Error: ZCL command 0x7cb03eaa0a0c544b/3 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (203) Error: waiting for response TIMEOUT)'
Also a test in z2m log:
error 2025-01-29 21:18:32z2m: Publish 'set' 'state' to 'Xbox' failed: 'Error: ZCL command 0x7cb03eaa00b1b02d/3 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (249) Error: waiting for response TIMEOUT)'
warning 2025-01-29 21:19:59z2m: Failed to ping 'Repeater Bad' (attempt 1/2, ZCL command 0x7cb03eaa0a0c544b/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (2) Error: waiting for response TIMEOUT))
warning 2025-01-29 21:20:12z2m: Failed to ping 'Repeater Bad' (attempt 2/2, ZCL command 0x7cb03eaa0a0c544b/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (3) Error: waiting for response TIMEOUT))
error 2025-01-29 21:20:28z2m: Publish 'set' 'state' to 'Xbox' failed: 'Error: ZCL command 0x7cb03eaa00b1b02d/3 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (6) Error: waiting for response TIMEOUT)'
