Z2M + Senic Friends of Hue + Philips hue direct bind
I just got PTM 215Z
I did try different ways to bind it to Philips Hue light bulb but got nothing
I’ve added both into Z2M and tried to hold buttons on Senic for 7-10 seconds, read logs and nothing. Than only thing is that Senic sends “unknown_96” action/command and that’s it.
I’ve tried to read “sinkTable” (of bulb) and write to it - not possible.
As far as I read - Philips did block sinkTable for a reason, so Users need to buy Bridge, but maybe you know a way…
Is there any possible way to direct bind those hardware?
Unfortunately, no.
Green Power devices don’t support binding and are not included in network scans.
See:
Thank you for quick response
Is there any switch (non philips, wall switch) which can do that? I still want to have ability to turn on/off (and dimm and change temperature) when HA is down
Unfortunately, I can’t answer that. I guess so, but I don’t know for sure. You should start a new thread about it, e.g., “Wall switch with support for direct binding in Zigbee2MQTT.”
