Zapato Carbon Monoxide Sensor - Integration
Does anyone have experience integrate this in Home Assistant?
If you use the ZWaveJS UI addon you should have no problem integrating it into Home Assistant. I checked the ZWaveJS database and there is an entry for the device so it should work. https://devices.zwave-js.io
Thank you, will look into it
