Zappi Fast mode not working in automation
I’m trying to automate my setup to make best use of Octopus Power Up periods where electricity is free for a time.
I ma using calendar event start and end as my triggers to set it up and reset at the end which is working fine.
The problem is getting my zappi charger to charge my car.
When the event start triggers I set up
  1. My solar battery to charge and draw all power from the grid. That works fine.
  2. Turn off Octopus Intelligent Smart Charge .
  3. Check the zappi plug status is Connected.
  4. If Connected then set zappi Charge Mode to Fast.
It does everything, including setting charge mode to Fast but the charge mode reverts back to eco++ after a couple of minutes. I then have to set it manually via the myenergi app or zappi front panel.
Anyone know what I’m missing/where I’m going wrong?
Automation code below for reference.
alias: Octopus Power Up Start
description: >-
  Uses calendar event to swich on Battery first and EV Boost charge during
  Octopus Power Up
triggers:
  - trigger: calendar
    entity_id: calendar.octopus_power_ups
    event: start
    offset: "0:0:0"
conditions: []
actions:
  - action: switch.turn_off
    metadata: {}
    data: {}
      entity_id: switch.octopus_energy_a_********_intelligent_smart_charge
  - action: script.turn_on_growatt_battery_first
    metadata: {}
    data: {}
  - if:
      - condition: state
        entity_id: sensor.myenergi_zappi_********_plug_status
        state: EV Connected
    then:
      - action: select.select_option
        metadata: {}
          option: Fast
          entity_id: select.myenergi_zappi_********_charge_mode
mode: single
I just got a Zappi and I am seeing something similar, if my automation (or manually in HA) changes the mode it seems to apply but reverts after a few seconds/minutes. I think that the change is being sent to the Zappi api but its not actually applying properly then HA reads the current state and shows it as the previous value (as in unchanged API side) and it overrides the HA value shown.
Hi All
I got sick of there being no local way to control my Zappi and I have had issues controlling it at times so I created this device to control it locally via MQTT, Webserver and Home Assistant. I think this is important as MyEnergi shutdown the local API discussion here.
Its not perfect but it works and is local. The link is here Local Zappi. Let me know what you think?
