Hi all, my ZBT-1 seems to be unable to update from version 7.4.4.1 to 7.4.4.2 and I’m getting the following error:
Failed to perform the action update/install. Failed to flash firmware
Any thoughts on how to fix this? Thanks!
Screenshot:
Screenshot:
Did you disable ZHA/zigbee2mqtt?
^^^ you must temporarily disable zha/z2m to update the firmware, the installer doesn’t do it for you, and the dongle only works with 1 thing at a time.
Stopping zigbee2mqtt did it for me. Thanks all!
I’ve had a similar problem with a SkyConnect. HA suggested to do a firmware update on the device and it didn’t succeed, probably because I didn’t disable ZHA. I had to complete the firmware update using the Silicon Labs Flasher add-on.
Same thing applies: Before you run the Silicon Labs Flasher add-on, you must disable ZHA.
For me the firmware update didn’t work until I entered a specific .gbl file URL in the optional configuration section. These .gbl file URLs are located here: https://github.com/NabuCasa/silabs-firmware-builder/releases
I used: skyconnect_zigbee_ncp_7.4.4.3.gbl
I’ve missed some specific points here.
If you’ve started trying to enable Zigbee in Integrations, you need to specifically do the following - as the firmware update is only recognized after you’ve actually enabled ZHA:
Everything else failed for me. First thing after disabling and rebooting is to go straight to the firmware update not through the notifications, but through the device tabs.
