I’m trying to set up ZBT-1 as a thread router but it fails on the OpenThread firmware flash. I’m following these instructions:
And this is the error I get:
Failed to flash firmware
File "/usr/src/homeassistant/homeassistant/components/homeassistant_hardware/util.py", line 421, in async_flash_silabs_firmware
await flasher.enter_bootloader()
File "/usr/local/lib/python3.13/site-packages/universal_silabs_flasher/flasher.py", line 358, in enter_bootloader
await self.probe_app_type()
File "/usr/local/lib/python3.13/site-packages/universal_silabs_flasher/flasher.py", line 329, in probe_app_type
raise RuntimeError("Failed to probe running application type")
RuntimeError: Failed to probe running application type
File "/usr/src/homeassistant/homeassistant/components/homeassistant_hardware/firmware_config_flow.py", line 203, in _install_firmware_step
await self.firmware_install_task
File "/usr/src/homeassistant/homeassistant/components/homeassistant_hardware/firmware_config_flow.py", line 310, in _install_firmware
self._probed_firmware_info = await async_flash_silabs_firmware(
...<9 lines>...
File "/usr/src/homeassistant/homeassistant/components/homeassistant_hardware/util.py", line 430, in async_flash_silabs_firmware
raise HomeAssistantError("Failed to flash firmware") from err
homeassistant.exceptions.HomeAssistantError: Failed to flash firmware
Anyone have any suggestions on how to resolve?
