ZBT-1 USB Dongle with Synology NAS DS923+
Hi -
(I figured out the problem half way through writing this post - skip to finish line if you are facing the sme issue)
I’m new to this forum and new to Home Automation.
I am trying to setup the latest version of HA in a Docker container on a Synology NAS DS923+ running Disk Station Manager.
My system:
Model: DS923+
OS Version: DSM 7.2.2-72806 Update 3
CPU: AMD Ryzen R1600
Package Architecture: R1000
I bought the HA Connect ZBT-1 (NC-ZBT-9710) here:
I have read the guide here on the HA website under installation / alternative.
Since I need to expose the USB Dongle to the Docker container, I need to know the path to the USB stick.
But it looks like the USB stick is not recognized by DSM.
Not much in dmesg when I plug in the ZBT-1:
Command lsusb shows the device, but does not give me the path to the device.
Nothing new or change in /dev/ after plugging in the ZBT-1.
At this point I figured I probably didnt have the right drivers, I have followed this guide but get the same result with the drivers installation.
What I didnt do is READ THE READ ME !
It clearly says:
If you use a CLI tool like wget or curl to download the files, you also need the “raw” URL:
So instead ot running the wget command with the ‘/tree/’ in the URL, I had to replace it with ‘/raw/’. This is just how github works.
Afterwards I followed the rest of the guide and the dirvers installed properly.
I rebooted my Synology and can now see the path to the device in /dev/ and in dmseg.
Et voilà.
On to the next steps.
Is there a reason why you chose to install a Docker container versus installing the VMware version of HAOS under Synology VMM? HAOS is much easier to manage for someone new to HA…
Thank you for reading the README and not opening an issue for this :wink:
Not really. Trying out new things? Less ressources intensive as I understand?
Thank you for the drivers :wink:
…at the expense of being more labor-intensive to manage. Keep this in mind if you are ever following an online HA tutorial and can’t find a menu option for something that’s bundled in HAOS, which I’ve seen happen way too many times to new HA users including me who start out with the Docker version and later discover its limitations…
