I didn’t have a smooth transition either. Despite updating the ZBT-1 firmware a day before, following the Z2M configuration steps in the end I had to copy the serial location and set the baud rate for the ZBT-2. I’m also scratching my head as to why so many devices have a low (as in very) LQI than with the ZBT-1.
I have a 2nd ZBT-2 coming, that was to be used for Thread. I figure first I’ll use that to create a 2nd Z2M configuration to slowly reset devices and rebuild the network.
[shrug?]
[edit]. In case the consideration of re-doing my devices sounds odd, that’s because I was sort of forced so use ch.15 in the process of getting rid of two Hue hubs in past months. Before moving to Z2m I had to use the Hue hubs for the Aurora rotary dimmers scattered through the house. I believe (?) that it would be ideal to have the Z2M using ch.25. I think I’m just searching for reasons the LQI sorta sucks with this new coordinator. FWIW
Same! I’ve rejoined everything, but signal strength from coordinator to direct device is significantly lower than the ZBT-1… which is very strange for a much bigger antenna and increased tx power…
