Zehnder ComfoAir Q350 + LAN-C – Home Assistant integration connects but is unusable (no sensors / no control, always errors). What is the recommended integration approach now?
I’m using a Zehnder ComfoAir Q350 with ComfoConnect LAN-C.
Current behaviour with Home Assistant (core ComfoConnect integration):
- Integration connects to the device
- But no sensors are returned and no control works
- Always results in “unexpected error” / timeout behaviour when trying to interact
Other observations:
- Zehnder ComfoControl app works locally without issue
- Google Home can see the device but reports it as offline
- Network is stable, same subnet, static IP
- Removed custom_components override and tested clean HA setup
It feels like LAN-C accepts the connection but does not respond properly to commands or complete registration.
Before I go further (e.g. wiring relays or moving to Modbus):
What is the currently recommended way to integrate ComfoAir Q / ComfoCoolQ with Home Assistant?
- Is the LAN-C integration still viable?
- Or generally considered unreliable / legacy?
Are people successfully using LAN-C with HA in a stable way?
For those wanting:
- Away / Boost control
- Supply / extract / outdoor / exhaust temperatures
- Humidity
what setup are you actually using in practice?
If starting again today, would you:
- Stick with LAN-C
- Use MQTT bridge
- Move to Modbus (ComfoConnect Pro)
- Or something else?
