I’m aware that there are a few similar type topics floating around, but wanted to throw my hat into the ring for my specific permutation.
tl;dr this is my first Matter over Thread device, it can connect to either Google Home or Apple Homekit, but can’t seem to pass along/pair to Home Assistant no matter the flow.
As far as my particular topography, I have ipv6 enabled at the router level (though the ISP doesn’t seem to assign anything externally), flat lan (no separate-vlans) HomePod minis and some Nest Hubs floating around the house and Home Assistant installed via VM.
I’ve tried uninstalling and reinstalling the Matter server and Thread Add-on in HOAS, to see if there was something I had tweaked by accident, but default settings and trying to pass the device from Google Home app over to HOAS on mobile results in the following logs:
Add-on: Matter Server
Matter WebSocket Server for Home Assistant Matter support.
Add-on version: 8.1.1
You are running the latest version of this add-on.
System: Home Assistant OS 16.3 (amd64 / qemux86-64)
Home Assistant Core: 2025.11.1
Home Assistant Supervisor: 2025.11.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service matter-server: starting
s6-rc: info: service matter-server successfully started
s6-rc: info: service legacy-services: starting
[09:50:52] INFO: Starting Matter Server...
s6-rc: info: service legacy-services successfully started
[09:50:53] INFO: Using 'enp0s3' as primary network interface.
[09:50:53] INFO: Successfully send discovery information to Home Assistant.
2025-11-10 09:50:54.919 (MainThread) INFO [matter_server.server.stack] Initializing CHIP/Matter Logging...
2025-11-10 09:50:54.919 (MainThread) INFO [matter_server.server.stack] Initializing CHIP/Matter Controller Stack...
[1762797054.967051][117:117] CHIP:CTL: Setting attestation nonce to random value
[1762797054.969473][117:117] CHIP:CTL: Setting CSR nonce to random value
[1762797054.977715][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1762797055.007156][117:117] CHIP:DL: Wrote settings to /tmp/chip_kvs
[1762797055.007373][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_factory.ini
[1762797055.009412][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_config.ini
[1762797055.009642][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_counters.ini
[1762797055.028804][117:117] CHIP:DL: Wrote settings to /data/chip_counters.ini
[1762797055.028823][117:117] CHIP:DL: NVS set: chip-counters/reboot-count = 2 (0x2)
[1762797055.029167][117:117] CHIP:DL: Got Ethernet interface: enp0s3
[1762797055.029337][117:117] CHIP:DL: Found the primary Ethernet interface:enp0s3
[1762797055.029691][117:117] CHIP:DL: Failed to get WiFi interface
[1762797055.029704][117:117] CHIP:DL: Failed to reset WiFi statistic counts
[1762797055.029710][117:117] CHIP:PAF: WiFiPAF: WiFiPAFLayer::Init()
2025-11-10 09:50:55.030 (MainThread) INFO [chip.storage] Initializing persistent storage from file: /data/chip.json
2025-11-10 09:50:55.030 (MainThread) INFO [chip.storage] Loading configuration from /data/chip.json...
2025-11-10 09:50:55.080 (MainThread) INFO [chip.CertificateAuthority] Loading certificate authorities from storage...
2025-11-10 09:50:55.080 (MainThread) INFO [chip.CertificateAuthority] New CertificateAuthority at index 1
2025-11-10 09:50:55.081 (MainThread) INFO [chip.CertificateAuthority] Loading fabric admins from storage...
2025-11-10 09:50:55.081 (MainThread) INFO [chip.FabricAdmin] New FabricAdmin: FabricId: 0x0000000000000002, VendorId = 0x134B
2025-11-10 09:50:55.082 (MainThread) INFO [matter_server.server.stack] CHIP Controller Stack initialized.
2025-11-10 09:50:55.082 (MainThread) INFO [matter_server.server.server] Matter Server initialized
2025-11-10 09:50:55.082 (MainThread) INFO [matter_server.server.server] Using 'enp0s3' as primary interface (for link-local addresses)
2025-11-10 09:50:55.083 (MainThread) INFO [matter_server.server.server] Starting the Matter Server...
2025-11-10 09:50:55.104 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Skip fetching certificates (already fetched within the last 24h).
2025-11-10 09:50:55.104 (MainThread) INFO [chip.FabricAdmin] Allocating new controller with CaIndex: 1, FabricId: 0x0000000000000002, NodeId: 0x000000000001B669, CatTags: []
2025-11-10 09:50:55.158 (MainThread) INFO [matter_server.server.vendor_info] Loading vendor info from storage.
2025-11-10 09:50:55.161 (MainThread) INFO [matter_server.server.vendor_info] Loaded 365 vendors from storage.
2025-11-10 09:50:55.161 (MainThread) INFO [matter_server.server.vendor_info] Fetching the latest vendor info from DCL.
2025-11-10 09:50:55.204 (MainThread) INFO [matter_server.server.vendor_info] Fetched 364 vendors from DCL.
2025-11-10 09:50:55.204 (MainThread) INFO [matter_server.server.vendor_info] Saving vendor info to storage.
2025-11-10 09:50:55.206 (MainThread) INFO [matter_server.server.device_controller] Loaded 0 nodes from stored configuration
2025-11-10 09:50:55.209 (MainThread) INFO [matter_server.server.server] Matter Server successfully initialized.
2025-11-10 09:56:34.561 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning with code using Node ID 2.
2025-11-10 09:57:04.573 (Dummy-2) CHIP_ERROR [chip.native.CTL] Discovery timed out
2025-11-10 09:57:12.213 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:39620i with Node: <0000000000000000, 0> S:0 M:131387973] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2025-11-10 09:57:20.952 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2025-11-10 09:57:58.251 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:39621i with Node: <0000000000000000, 0> S:0 M:131387974] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2025-11-10 09:58:07.269 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2025-11-10 09:58:45.503 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:39622i with Node: <0000000000000000, 0> S:0 M:131387975] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2025-11-10 09:58:53.586 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2025-11-10 09:59:30.520 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:39623i with Node: <0000000000000000, 0> S:0 M:131387976] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2025-11-10 09:59:39.902 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2025-11-10 09:59:39.902 (Dummy-2) CHIP_ERROR [chip.native.ZCL] Secure Pairing Failed
2025-11-10 09:59:39.902 (Dummy-2) WARNING [chip.ChipDeviceCtrl] Failed to establish secure session to device: src/controller/python/ChipDeviceController-ScriptDevicePairingDelegate.cpp:96: CHIP Error 0x00000003: Incorrect state
2025-11-10 09:59:39.903 (MainThread) ERROR [matter_server.server.client_handler] [139899780441456] Error while handling: commission_with_code: Commission with code failed for node 2.
A more detailed Homekit → HOAS add attempt seemingly has the same results:
2025-11-10 10:35:36.465 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning with code using Node ID 5.
2025-11-10 10:35:36.466 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Setting attestation nonce to random value
2025-11-10 10:35:36.467 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Setting CSR nonce to random value
2025-11-10 10:35:36.468 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Stopping commissionable node discovery over DNS-SD
2025-11-10 10:35:36.468 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Starting commissionable node discovery over DNS-SD
2025-11-10 10:35:36.473 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Discovered device with discriminator 63 matches one of our setup payloads
2025-11-10 10:35:36.473 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Discovered device to be commissioned over DNS-SD
2025-11-10 10:35:36.473 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Attempting PASE connection to UDP:[fd58:8a6b:718a:0:fcc2:8363:941d:7904]:5540
2025-11-10 10:35:36.474 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7fa6c000c8d0]: Allocated Type:1 LSID:146
2025-11-10 10:35:36.474 (Dummy-2) CHIP_DETAIL [chip.native.SC] Assigned local session key ID 146
2025-11-10 10:35:36.474 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<< [E:49642i S:0 M:146497137] (U) Msg TX from FA1CC4549B020B34 to 0:0000000000000000 [0000] [UDP:[fd58:8a6b:718a:0:fcc2:8363:941d:7904]:5540] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:97)
2025-11-10 10:35:36.474 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??1 [E:49642i with Node: <0000000000000000, 0> S:0 M:146497137] (U) Msg Retransmission to 0:0000000000000000 scheduled for 2475ms from now [State:Active II:3000 AI:2200 AT:4000]
2025-11-10 10:35:36.474 (Dummy-2) CHIP_PROGRESS [chip.native.SC] Sent PBKDF param request [II:500ms AI:300ms AT:4000ms)
2025-11-10 10:35:36.475 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Commission called for node ID 0x0000000000000005
2025-11-10 10:35:36.475 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Discovered device with discriminator 63 matches one of our setup payloads
2025-11-10 10:35:36.475 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Discovered device to be commissioned over DNS-SD
2025-11-10 10:35:36.576 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Discovered device with discriminator 63 matches one of our setup payloads
2025-11-10 10:35:36.576 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Discovered device to be commissioned over DNS-SD
2025-11-10 10:35:36.577 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Discovered device with discriminator 63 matches one of our setup payloads
2025-11-10 10:35:36.577 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Discovered device to be commissioned over DNS-SD
2025-11-10 10:35:38.952 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<1 [E:49642i with Node: <0000000000000000, 0> S:0 M:146497137] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:35:38.952 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??2 [E:49642i with Node: <0000000000000000, 0> S:0 M:146497137] (U) Msg Retransmission to 0:0000000000000000 scheduled for 2565ms from now [State:Active II:3000 AI:2200 AT:4000]
2025-11-10 10:35:41.520 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<2 [E:49642i with Node: <0000000000000000, 0> S:0 M:146497137] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:35:41.521 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??3 [E:49642i with Node: <0000000000000000, 0> S:0 M:146497137] (U) Msg Retransmission to 0:0000000000000000 scheduled for 5549ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:35:47.073 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<3 [E:49642i with Node: <0000000000000000, 0> S:0 M:146497137] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:35:47.074 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??4 [E:49642i with Node: <0000000000000000, 0> S:0 M:146497137] (U) Msg Retransmission to 0:0000000000000000 scheduled for 10521ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:35:57.602 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<4 [E:49642i with Node: <0000000000000000, 0> S:0 M:146497137] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:35:57.603 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??5 [E:49642i with Node: <0000000000000000, 0> S:0 M:146497137] (U) Msg Retransmission to 0:0000000000000000 scheduled for 14576ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:36:06.477 (Dummy-2) CHIP_ERROR [chip.native.CTL] Discovery timed out
2025-11-10 10:36:06.478 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Stopping commissionable node discovery over DNS-SD
2025-11-10 10:36:12.184 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:49642i with Node: <0000000000000000, 0> S:0 M:146497137] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2025-11-10 10:36:22.792 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2025-11-10 10:36:22.792 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7fa6c000c8d0]: Released - Type:1 LSID:146
2025-11-10 10:36:22.792 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Ignoring SecurePairingFailed status for now; we have more discovered devices to try
2025-11-10 10:36:22.793 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Attempting PASE connection to UDP:[fd58:8a6b:718a:0:fcc2:8363:941d:7904]:5540
2025-11-10 10:36:22.793 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7fa6c0009a60]: Allocated Type:1 LSID:147
2025-11-10 10:36:22.793 (Dummy-2) CHIP_DETAIL [chip.native.SC] Assigned local session key ID 147
2025-11-10 10:36:22.793 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<< [E:49643i S:0 M:146497138] (U) Msg TX from 3979AFDC61485E62 to 0:0000000000000000 [0000] [UDP:[fd58:8a6b:718a:0:fcc2:8363:941d:7904]:5540] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:97)
2025-11-10 10:36:22.794 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??1 [E:49643i with Node: <0000000000000000, 0> S:0 M:146497138] (U) Msg Retransmission to 0:0000000000000000 scheduled for 2737ms from now [State:Active II:3000 AI:2200 AT:4000]
2025-11-10 10:36:22.794 (Dummy-2) CHIP_PROGRESS [chip.native.SC] Sent PBKDF param request [II:500ms AI:300ms AT:4000ms)
2025-11-10 10:36:22.794 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Commission called for node ID 0x0000000000000005
2025-11-10 10:36:22.794 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Trying connection to commissionee over different transport
2025-11-10 10:36:25.533 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<1 [E:49643i with Node: <0000000000000000, 0> S:0 M:146497138] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:36:25.534 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??2 [E:49643i with Node: <0000000000000000, 0> S:0 M:146497138] (U) Msg Retransmission to 0:0000000000000000 scheduled for 2761ms from now [State:Active II:3000 AI:2200 AT:4000]
2025-11-10 10:36:28.297 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<2 [E:49643i with Node: <0000000000000000, 0> S:0 M:146497138] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:36:28.298 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??3 [E:49643i with Node: <0000000000000000, 0> S:0 M:146497138] (U) Msg Retransmission to 0:0000000000000000 scheduled for 6425ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:36:34.730 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<3 [E:49643i with Node: <0000000000000000, 0> S:0 M:146497138] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:36:34.731 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??4 [E:49643i with Node: <0000000000000000, 0> S:0 M:146497138] (U) Msg Retransmission to 0:0000000000000000 scheduled for 10323ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:36:45.065 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<4 [E:49643i with Node: <0000000000000000, 0> S:0 M:146497138] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:36:45.065 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??5 [E:49643i with Node: <0000000000000000, 0> S:0 M:146497138] (U) Msg Retransmission to 0:0000000000000000 scheduled for 16319ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:37:01.399 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:49643i with Node: <0000000000000000, 0> S:0 M:146497138] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2025-11-10 10:37:09.101 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2025-11-10 10:37:09.101 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7fa6c0009a60]: Released - Type:1 LSID:147
2025-11-10 10:37:09.101 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Ignoring SecurePairingFailed status for now; we have more discovered devices to try
2025-11-10 10:37:09.101 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Attempting PASE connection to UDP:[fd58:8a6b:718a:0:fcc2:8363:941d:7904]:5540
2025-11-10 10:37:09.102 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7fa6c000c8d0]: Allocated Type:1 LSID:148
2025-11-10 10:37:09.102 (Dummy-2) CHIP_DETAIL [chip.native.SC] Assigned local session key ID 148
2025-11-10 10:37:09.102 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<< [E:49644i S:0 M:146497139] (U) Msg TX from FCF1E259DC8C24FA to 0:0000000000000000 [0000] [UDP:[fd58:8a6b:718a:0:fcc2:8363:941d:7904]:5540] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:97)
2025-11-10 10:37:09.102 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??1 [E:49644i with Node: <0000000000000000, 0> S:0 M:146497139] (U) Msg Retransmission to 0:0000000000000000 scheduled for 2614ms from now [State:Active II:3000 AI:2200 AT:4000]
2025-11-10 10:37:09.102 (Dummy-2) CHIP_PROGRESS [chip.native.SC] Sent PBKDF param request [II:500ms AI:300ms AT:4000ms)
2025-11-10 10:37:09.103 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Commission called for node ID 0x0000000000000005
2025-11-10 10:37:09.103 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Trying connection to commissionee over different transport
2025-11-10 10:37:11.720 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<1 [E:49644i with Node: <0000000000000000, 0> S:0 M:146497139] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:37:11.721 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??2 [E:49644i with Node: <0000000000000000, 0> S:0 M:146497139] (U) Msg Retransmission to 0:0000000000000000 scheduled for 2756ms from now [State:Active II:3000 AI:2200 AT:4000]
2025-11-10 10:37:14.480 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<2 [E:49644i with Node: <0000000000000000, 0> S:0 M:146497139] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:37:14.481 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??3 [E:49644i with Node: <0000000000000000, 0> S:0 M:146497139] (U) Msg Retransmission to 0:0000000000000000 scheduled for 6008ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:37:20.495 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<3 [E:49644i with Node: <0000000000000000, 0> S:0 M:146497139] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:37:20.496 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??4 [E:49644i with Node: <0000000000000000, 0> S:0 M:146497139] (U) Msg Retransmission to 0:0000000000000000 scheduled for 9555ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:37:30.061 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<4 [E:49644i with Node: <0000000000000000, 0> S:0 M:146497139] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:37:30.062 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??5 [E:49644i with Node: <0000000000000000, 0> S:0 M:146497139] (U) Msg Retransmission to 0:0000000000000000 scheduled for 15315ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:37:45.391 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:49644i with Node: <0000000000000000, 0> S:0 M:146497139] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2025-11-10 10:37:55.418 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2025-11-10 10:37:55.419 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7fa6c000c8d0]: Released - Type:1 LSID:148
2025-11-10 10:37:55.419 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Ignoring SecurePairingFailed status for now; we have more discovered devices to try
2025-11-10 10:37:55.419 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Attempting PASE connection to UDP:[fd58:8a6b:718a:0:fcc2:8363:941d:7904]:5540
2025-11-10 10:37:55.419 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7fa6c00095c0]: Allocated Type:1 LSID:149
2025-11-10 10:37:55.419 (Dummy-2) CHIP_DETAIL [chip.native.SC] Assigned local session key ID 149
2025-11-10 10:37:55.420 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<< [E:49645i S:0 M:146497140] (U) Msg TX from 4D413A9D98BE3E50 to 0:0000000000000000 [0000] [UDP:[fd58:8a6b:718a:0:fcc2:8363:941d:7904]:5540] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:97)
2025-11-10 10:37:55.420 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??1 [E:49645i with Node: <0000000000000000, 0> S:0 M:146497140] (U) Msg Retransmission to 0:0000000000000000 scheduled for 2525ms from now [State:Active II:3000 AI:2200 AT:4000]
2025-11-10 10:37:55.420 (Dummy-2) CHIP_PROGRESS [chip.native.SC] Sent PBKDF param request [II:500ms AI:300ms AT:4000ms)
2025-11-10 10:37:55.420 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Commission called for node ID 0x0000000000000005
2025-11-10 10:37:55.420 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Trying connection to commissionee over different transport
2025-11-10 10:37:57.946 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<1 [E:49645i with Node: <0000000000000000, 0> S:0 M:146497140] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:37:57.946 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??2 [E:49645i with Node: <0000000000000000, 0> S:0 M:146497140] (U) Msg Retransmission to 0:0000000000000000 scheduled for 2704ms from now [State:Active II:3000 AI:2200 AT:4000]
2025-11-10 10:38:00.654 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<2 [E:49645i with Node: <0000000000000000, 0> S:0 M:146497140] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:38:00.654 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??3 [E:49645i with Node: <0000000000000000, 0> S:0 M:146497140] (U) Msg Retransmission to 0:0000000000000000 scheduled for 6152ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:38:06.813 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<3 [E:49645i with Node: <0000000000000000, 0> S:0 M:146497140] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:38:06.813 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??4 [E:49645i with Node: <0000000000000000, 0> S:0 M:146497140] (U) Msg Retransmission to 0:0000000000000000 scheduled for 9019ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:38:15.842 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<4 [E:49645i with Node: <0000000000000000, 0> S:0 M:146497140] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:38:15.842 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??5 [E:49645i with Node: <0000000000000000, 0> S:0 M:146497140] (U) Msg Retransmission to 0:0000000000000000 scheduled for 13876ms from now [State:Idle II:3000 AI:2200 AT:4000]
2025-11-10 10:38:29.733 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:49645i with Node: <0000000000000000, 0> S:0 M:146497140] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2025-11-10 10:38:41.737 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2025-11-10 10:38:41.737 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7fa6c00095c0]: Released - Type:1 LSID:149
2025-11-10 10:38:41.737 (Dummy-2) CHIP_ERROR [chip.native.ZCL] Secure Pairing Failed
2025-11-10 10:38:41.737 (Dummy-2) WARNING [chip.ChipDeviceCtrl] Failed to establish secure session to device: src/controller/python/ChipDeviceController-ScriptDevicePairingDelegate.cpp:96: CHIP Error 0x00000003: Incorrect state
2025-11-10 10:38:41.738 (MainThread) ERROR [matter_server.server.client_handler] [140354313483664] Error while handling: commission_with_code: Commission with code failed for node 5.
Attempting to add directly to Home Assistant from an Android device yields similar results:
2025-11-10 10:09:35.268 (MainThread) INFO [matter_server.server.server] Matter Server successfully initialized.
2025-11-10 10:12:44.347 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning using Node ID 3 and IP fd58:8a6b:718a:0:2ace:b9a8:64c3:1a1b.
2025-11-10 10:12:44.348 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7fa6c000c8d0]: Allocated Type:1 LSID:144
2025-11-10 10:12:44.348 (Dummy-2) CHIP_DETAIL [chip.native.SC] Assigned local session key ID 144
2025-11-10 10:12:44.348 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<< [E:49640i S:0 M:146497135] (U) Msg TX from 8CA3ED5543F0FFA1 to 0:0000000000000000 [0000] [UDP:[fd58:8a6b:718a:0:2ace:b9a8:64c3:1a1b]:5540] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:97)
2025-11-10 10:12:44.349 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??1 [E:49640i with Node: <0000000000000000, 0> S:0 M:146497135] (U) Msg Retransmission to 0:0000000000000000 scheduled for 344ms from now [State:Active II:500 AI:300 AT:4000]
2025-11-10 10:12:44.349 (Dummy-2) CHIP_PROGRESS [chip.native.SC] Sent PBKDF param request [II:500ms AI:300ms AT:4000ms)
2025-11-10 10:12:44.349 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Setting attestation nonce to random value
2025-11-10 10:12:44.349 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Setting CSR nonce to random value
2025-11-10 10:12:44.350 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] Commission called for node ID 0x0000000000000003
2025-11-10 10:12:44.693 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<1 [E:49640i with Node: <0000000000000000, 0> S:0 M:146497135] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:12:44.693 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??2 [E:49640i with Node: <0000000000000000, 0> S:0 M:146497135] (U) Msg Retransmission to 0:0000000000000000 scheduled for 350ms from now [State:Active II:500 AI:300 AT:4000]
2025-11-10 10:12:45.044 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<2 [E:49640i with Node: <0000000000000000, 0> S:0 M:146497135] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:12:45.045 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??3 [E:49640i with Node: <0000000000000000, 0> S:0 M:146497135] (U) Msg Retransmission to 0:0000000000000000 scheduled for 645ms from now [State:Active II:500 AI:300 AT:4000]
2025-11-10 10:12:45.691 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<3 [E:49640i with Node: <0000000000000000, 0> S:0 M:146497135] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:12:45.692 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??4 [E:49640i with Node: <0000000000000000, 0> S:0 M:146497135] (U) Msg Retransmission to 0:0000000000000000 scheduled for 871ms from now [State:Active II:500 AI:300 AT:4000]
2025-11-10 10:12:46.564 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<4 [E:49640i with Node: <0000000000000000, 0> S:0 M:146497135] (U) Msg Retransmission to 0:0000000000000000
2025-11-10 10:12:46.565 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??5 [E:49640i with Node: <0000000000000000, 0> S:0 M:146497135] (U) Msg Retransmission to 0:0000000000000000 scheduled for 1686ms from now [State:Active II:500 AI:300 AT:4000]
2025-11-10 10:12:48.253 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:49640i with Node: <0000000000000000, 0> S:0 M:146497135] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2025-11-10 10:12:54.797 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2025-11-10 10:12:54.797 (Dummy-2) CHIP_DETAIL [chip.native.IN] SecureSession[0x7fa6c000c8d0]: Released - Type:1 LSID:144
2025-11-10 10:12:54.797 (Dummy-2) CHIP_ERROR [chip.native.ZCL] Secure Pairing Failed
2025-11-10 10:12:54.798 (Dummy-2) WARNING [chip.ChipDeviceCtrl] Failed to establish secure session to device: src/controller/python/ChipDeviceController-ScriptDevicePairingDelegate.cpp:96: CHIP Error 0x00000003: Incorrect state
2025-11-10 10:12:54.798 (MainThread) ERROR [matter_server.server.client_handler] [140354313483664] Error while handling: commission_on_network: Commissioning failed for node 3.
Attempting to add directly to Home Assistant from an iOS device seemingly fails at an earlier stage; no logs, the commission progress just gets stuck at the “Setting up…” phase indefinitely after the phone connects to the device.
I’m at a lost as to what needs to change in my setup to get this sort of thing to work, or if it’s just a lost cause and I should stick to Zwave/Zigbee lol.
