Zemismart Rechargeable Blind Motor ZM25AZ01
Hi
I have a Zigbee Zemismart ZM25AZ01 Blind motor, it pairs and sets up via Zigbee2MQTT with no issues, up, down limits and reverse work fine but when accessed through home assistant it will only operate one in on direction with the other direction greyed out, I have tried the Home Assistant experimental event entities & Home Assistant legacy action sensors enabled and disabled but makes no differance, any advice?
David
Same issue here. Do you also encounter the Roller not responding to Zigbee2MQTT commands at all after a while, only waking up after the included remote is used?
This is what my device reports as on Zigbee2MQTT:
  manufacturer: Hiladuo
  model: Motorized roller shade
  model_id: B09M3R35GC
Kevin
I have made some progress if you go into Zigbee2MQTT and select the device then go to Settings (specific) and enable invert cover that solves the Up/Down Issue. You might need to activate the motor with the remote to get Home assistant back in sync. Yes mine reports as the wrong device also but it works fine.
Not had it stop working yet but I will not use the remote for a while and see if it goes into a sleep mode.
Hope this helps
David
Hi! Thank you for the advice. It corrects the direction used, but it still happens to be greyed out as it was.
Bummer are you sure you changed the invert blind in the settings specific tab and not the reverse direction in the exposes tab. Also I have not used the remote for 24hrs and still responding to ZigBee commands.
