Zemismart Roller blind motor misbehaving
This fix has been incorporated into Z2M code base:
I hope we’ll see it released next month after which the custom converter can be deleted.
Thank you SO much for putting this together! I have about a dozen or so Hiladuo B09M3R35GC shades (rebranded TS0601) and 4 of them were exhibiting this exact behavior. A few changes to your converter and they’re back to normal!
I use the MQTT Explorer addon, it’s great.
amazing, thanks!
When will this be released? Im having the same issue with ZMEL25 zigged blinds… 10 messages per second. Only started recently
Same problem here the mentioned fix seems no to work for me
thanks for posting on this. I was away for several weeks and came home to 10 (!!!) dead blinds. Charging them up, they just drain again right away. Seems I’m running into this too. Really too bad since the zemismart blinds have been running great for almost 2 years now.
However, i’m not seeing a lot of chatter in the logs. Neither is there a bunch of activity in mqtt. Is there any other way to confirm the cause or trace this?
Thanks!
Wasn’t this fix meant to be added to the release of a few days ago? I didn’t see it in the release notes. :frowning:
