Hi everyone i hope that you are having a great day.
Im planning on buying a lot of zigbee switches for a client, and i think that i´ll get some Zemismart ones. Had anyone have any experience with them?
On what im more intrested is how well do they repeat zigbee signal (neutral wired version) and are them any good in general? Im getting the US version but i think they have the same software.
Thanks for your help.
Have no direct experience with zemismart, but general rule of thumb for mains powered zigbee devices is this:
- No Neutral (has no neutral terminal at all): does not route zigbee mesh.
- No Neutral required(has a neutral terminal but it’s optional): still does not route zigbee mesh.
- Neutral required: will route zigbee mesh.
Letting you know so you triple check the listing & if necessary ask their support or get a sample before you commit to a huge spend.
Thanks for the information very important to triple check that, I have some moes switches that neutral are optional but if wired they don’t work as repeaters, the ones in attempting to get from zemismart states that they are neutral wired versions and do work as repeaters.
My concern is the quality of signal repeated and also if they are compatible with direct binding from z2m.
The model is zms-208US
hi, ZMS-208US is zigbee neutral, can act as reapter function.
Does the ZMS-208US support detatching the relay when a neutral wire is present?
The ZMS-208US does not support the function.
