blueprint:
name: Zemismart ZMR4 - ZHA Events
description: Easily setup your Zemismart ZMR4 4-Button Switch using ZHA events
domain: automation
source_url: https://github.com/YOUR_USERNAME/zemismart-zmr4-blueprint
author: YOUR_NAME
input:
zemismart_device:
name: Zemismart ZMR4 Device
description: Select your Zemismart ZMR4 device you want to configure actions for.
selector:
device:
multiple: false
button1_sp:
name: Action SP Button 1 (Endpoint 1)
default:
description: Action Type for single pressing Button 1 (Endpoint 1)
selector:
action: {}
button1_dp:
name: Action DP Button 1 (Endpoint 1)
default:
description: Action Type for double pressing Button 1 (Endpoint 1)
selector:
action: {}
button1_lp:
name: Action LP Button 1 (Endpoint 1)
default:
description: Action Type for long pressing Button 1 (Endpoint 1)
selector:
action: {}
button2_sp:
name: Action SP Button 2 (Endpoint 2)
default:
description: Action Type for single pressing Button 2 (Endpoint 2)
selector:
action: {}
button2_dp:
name: Action DP Button 2 (Endpoint 2)
default:
description: Action Type for double pressing Button 2 (Endpoint 2)
selector:
action: {}
button2_lp:
name: Action LP Button 2 (Endpoint 2)
default:
description: Action Type for long pressing Button 2 (Endpoint 2)
selector:
action: {}
button3_sp:
name: Action SP Button 3 (Endpoint 3)
default:
description: Action Type for single pressing Button 3 (Endpoint 3)
selector:
action: {}
button3_dp:
name: Action DP Button 3 (Endpoint 3)
default:
description: Action Type for double pressing Button 3 (Endpoint 3)
selector:
action: {}
button3_lp:
name: Action LP Button 3 (Endpoint 3)
default:
description: Action Type for long pressing Button 3 (Endpoint 3)
selector:
action: {}
button4_sp:
name: Action SP Button 4 (Endpoint 4)
default:
description: Action Type for single pressing Button 4 (Endpoint 4)
selector:
action: {}
button4_dp:
name: Action DP Button 4 (Endpoint 4)
default:
description: Action Type for double pressing Button 4 (Endpoint 4)
selector:
action: {}
button4_lp:
name: Action LP Button 4 (Endpoint 4)
default:
description: Action Type for long pressing Button 4 (Endpoint 4)
selector:
action: {}
trigger_variables:
var_device_id: !input zemismart_device
- platform: event
event_type: zha_event
event_data:
device_id: "{{ var_device_id }}"
endpoint_id: 1
command: remote_button_short_press
- platform: event
event_data:
endpoint_id: 1
command: remote_button_double_press
- platform: event
event_data:
endpoint_id: 1
command: remote_button_long_press
- platform: event
event_data:
endpoint_id: 2
- platform: event
event_data:
endpoint_id: 2
- platform: event
event_data:
endpoint_id: 2
- platform: event
event_data:
endpoint_id: 3
- platform: event
event_data:
endpoint_id: 3
- platform: event
event_data:
endpoint_id: 3
- platform: event
event_data:
endpoint_id: 4
- platform: event
event_data:
endpoint_id: 4
- platform: event
event_data:
endpoint_id: 4
- choose:
- conditions:
- condition: trigger
sequence: !input button1_sp
- conditions:
sequence: !input button1_dp
- conditions:
sequence: !input button1_lp
- conditions:
sequence: !input button2_sp
- conditions:
sequence: !input button2_dp
- conditions:
sequence: !input button2_lp
- conditions:
sequence: !input button3_sp
- conditions:
sequence: !input button3_dp
- conditions:
sequence: !input button3_lp
- conditions:
sequence: !input button4_sp
- conditions:
sequence: !input button4_dp
- conditions:
sequence: !input button4_lp
Hello Billnyc,
Is it your intention to share this on the Blueprint Exchange?
If so this is the wrong category (you can change that with the pencil in the title line) and I suggest adding a little more text to explain what it is and why it’s different from the other ones for the same hardware.
Also I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
ah thank you! yes I want to add to the blueprint exchange, was not sure how to do this.
