Some of the switch modules have a setting to set the type of analogue wall switch you can use to trigger the switch module. The options are either toggle or momentary. In ZigbeetoMQTT it’s implemented by the “Switch_Type” command.
That looks like this in the Herdsman Adapter:
xiaomi_switch_type: {
key: [‘switch_type’],
convertSet: async (entity, key, value, meta) => {
const lookup = {‘toggle’: 1, ‘momentary’: 2};
value = value.toLowerCase();
utils.validateValue(value, Object.keys(lookup));
await entity.write(‘aqaraOpple’, {0x000A: {value: lookup[value], type: 0x20}}, manufacturerOptions.xiaomi);
return {state: {switch_type: value}};
convertGet: async (entity, key, meta) => {
await entity.read(‘aqaraOpple’, [0x000A], manufacturerOptions.xiaomi);
What would be the zigbee cluster setting for this attribute?
For example:
service: zha.set_zigbee_cluster_attribute
service data:
ieee: ‘84:2e:14:aa:bb:cc:eb:c0’
endpoint_id: 1
cluster_id: 513
attribute: 16387
cluster_type: out
value: 1
manufacturer: ‘4678’
It’s xiaomi specific and I don’t find it anywhere mentioned in any of the specifications…
From the code I would expect this data:
ieee: 54:ef:44:10:00:20:06:9e
endpoint_id: 1
cluster_id: 64704
cluster_type: in
attribute: 10
value: 2
But it does not have any effect…
No, I installed a toggle switch
Hedda
(Hedda)
May 11, 2022, 11:09am
5
FYI, see this related “switch_type” development discussion for ZHA and zigpy here:
https://github.com/zigpy/zigpy/discussions/934
Summery is that ZHA developers are working on adding configuration to ZHA but you will probably still need a ZHA quirk in ZHA Device Handlers library/repository for the devices as well so submit request:
https://github.com/zigpy/zha-device-handlers/issues/1231
https://github.com/zigpy/zha-device-handlers/blob/b802c1fb2cf2682f9a4722bfb57a1958cad9dad7/README.md
https://www.home-assistant.io/integrations/zha#zha-exception-and-deviation-handling
This is also discussed here:
https://community.home-assistant.io/t/aqara-switch-module-t1-rebound-switch/345580/
I have a few Aqara T1s that I want to respond to a rebound switch. I know if I add it to an Aqara hub, I can adjust some settings in the Aqara hub - but is there any way of doing it without having a hub?
