Another question about the ZHA and Blitzwolf SHP 15, all seems to be ok.
But if I turn the device on/off (on the device itself) Home Assistant wont register it. Other way around, switching in Home assistant, does turn the device on/off.
The Blitzwolf SHP 15 shows up as:
model": “TS011F
device_type”: "0x010a
“node_descriptor”: “NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)”,
“endpoints”: {
“1”: {
“profile_id”: 260,
“device_type”: “0x010a”,
“in_clusters”: [
“0x0000”,
“0x0003”,
“0x0004”,
“0x0005”,
“0x0006”,
“0x0702”,
“0x0b04”,
“0xe000”,
“0xe001”
“out_clusters”: [
“0x000a”,
“0x0019”
“manufacturer”: “_TZ3000_u5u4cakc”,
“model”: “TS011F”,
“class”: “zhaquirks.tuya.ts011f_plug.Plug”
all my other devices Blitzwolf SHP 13 are working correct and show up as model: TS0121
Can somebody verify my findings? thanks in advance.
Regards Frank
