ZHA cannot see devices after reinstallation
Hi there. I’m running Home Assistant on a RasPi4. I’m using ZHA and a RaspBeeII to connect 3 Zigbee devices so far (2 Niko Zigbee switches and 1 LED driver). Everything was running fine, but I decided I should not use a SD card as my system disk and reinstalled everything in a Geeekpi Deskpi with a SATA M.2 SSD.
That’s where I ran out of luck.
I installed a fresh system (using Pi Imager, just as the first install in my SD card) and used a backup of the previous system to restore everything (worked ok with a little glitch, I can explain later if necessary).
I then had to reinstall RaspBeeII (partly because I had not plugged it in right and so deleted it trying to make it work… whatever). Now I’ve got RaspBeeII recognized ok in ZAH. But when I try to add my devices, ZHA can’t find any of them. I did put them in pairing mode, and even did a reset on the Niko switches, but no way : nothing is seen by ZHA.
I don’t know where to start to debug this. Can someone help ?
Thanks in advance :slight_smile:
