Zha cluster unreadable with sonoff sensors
Hey! I’m having issues reading the attribute value for my sonoff Sensor devices (motion and temperature). I’m using the sonoff zigbee USB dongle as my zigbee controller and everything else is working perfectly. With my hue products I can easily access the cluster attributes, but not the sonoffs… any ideas? Thanks!
Try zha_toolkit/scan_device to check if that can read your attributes.
Are they manufacturer attributes? Make sure that you add the manufacturer id in the request.
In some cases Zigpy will add the manufacturer, but the attribute must be declared as requiring a manufacturer id. If you’re lucky a quirk does that for you.
