I have ZHA Integration via Conbee II stick with around ~10 devices. Raspberry Pi 4 with Hass.io (core-2021.5.0).
Usually everything works fine, however sometimes (quite often!) after the reboot, the Conbee II seems not to start properly. When that happens I usually see in the logs:
2021-05-07 16:40:26 ERROR (MainThread) [zigpy_deconz.uart] Lost serial connection: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2021-05-07 16:40:26 WARNING (MainThread) [zigpy_deconz.api] Serial '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2429010-if00' connection lost unexpectedly: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2021-05-07 16:40:28 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.read_parameter' command with seq id '0x02'
2021-05-07 16:40:28 ERROR (MainThread) [zigpy.application] Couldn't start application
2021-05-07 16:40:28 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 157, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.8/site-packages/zigpy/application.py", line 69, in new
await app.startup(auto_form)
File "/usr/local/lib/python3.8/site-packages/zigpy_deconz/zigbee/application.py", line 66, in startup
self.version = await self._api.version()
File "/usr/local/lib/python3.8/site-packages/zigpy_deconz/api.py", line 455, in version
(self._proto_ver,) = await self[NetworkParameter.protocol_version]
File "/usr/local/lib/python3.8/site-packages/zigpy_deconz/api.py", line 420, in read_parameter
r = await self._command(Command.read_parameter, 1 + len(data), param, data)
File "/usr/local/lib/python3.8/site-packages/zigpy_deconz/api.py", line 305, in _command
return await asyncio.wait_for(fut, timeout=COMMAND_TIMEOUT)
File "/usr/local/lib/python3.8/asyncio/tasks.py", line 501, in wait_for
raise exceptions.TimeoutError()
asyncio.exceptions.TimeoutError
2021-05-07 16:40:28 WARNING (MainThread) [homeassistant.config_entries] Config entry 'ConBee II, s/n: DE2429010 - dresden elektronik ingenieurtechnik GmbH' for zha integration not ready yet; Retrying in background
or:
2021-05-07 16:47:16 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.read_parameter' command with seq id '0x02'
2021-05-07 16:47:16 ERROR (MainThread) [zigpy.application] Couldn't start application
2021-05-07 16:47:16 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
2021-05-07 16:47:16 WARNING (MainThread) [homeassistant.config_entries] Config entry 'ConBee II, s/n: DE2429010 - dresden elektronik ingenieurtechnik GmbH' for zha integration not ready yet; Retrying in background
As a consequence, strangely enough, power-connected zigbee switches seems to work OK, however all battery-based buttons seems to be unresponsive.
What helps is⌠Server Controls â Server Management â Reboot. Sometimes it needs 2-3 reboots before it loads properly.
What I tried:
- I updated conbee II stick via windows 10 to the newest available version
- I âmovedâ conbee II from USB3 port to USB2 port + added a cable extention (about 1 meter).
Regardless of âsuccessfulâ or âunsucessfulâ ZHA+Conbee II integration after restart, I always see in the logs:
2021-05-07 16:47:21 WARNING (MainThread) [zigpy.zcl] Unknown cluster 57344
2021-05-07 16:47:21 WARNING (MainThread) [zigpy.zcl] Unknown cluster 57345
