This worked perfectly for me using z2m 2.1.3 and HomeAssistant 2025.3.4 with an Ikea E2002 and a Gledopto GL-B-007Z. Thank you for sharing.
I am trying to implement what you describe but I have a hard time putting the pieces together. I have created the input select with the list of lamps I want to control. I also have created the input number and I have linked it to the arrow buttons on the styrbar remote.
What I cannot figure out is:
- How to tie the numbers to the input select.
- How to refer to the input select in the light hook blueprint. I tried to edit the yaml version simply using input_select.my_list for the lamp: value. It does not return an error but it does nothing.
Any help would be highly appreciated.
Hi mate, I did some changes from then
Basically assign buttons to control the list only
data: {}
entity_id: input_select.e2002_02_devicectrl
action: input_select.select_next
enabled: true
Now I’ve never used light hooks, I do my control from the styrbar remote buttons directly.
transition: 1
brightness_step: -10
entity_id: "{{ states(\"input_select.e2002_02_devicectrl\") }}"
action: light.turn_on
enabled: true
Hope it helps if not share your code and when I’ll eyeball it when I get a chance
Thanks a lot. This is what I needed to make it work without light hooks.
My next step consists of making a long press dim the lights. I have assigned the following code to the long press action for the up button:
entity_id: "{{ states(\"input_select.lampes_sam\") }}"
enabled: true
brightness_step_pct: 5
It does increase brightness but I am missing the code to do it continuously until I stop pressing the button. Sorry to ask all these basic questions, but I was not able to find adequate reference on the syntax to use to implement these features.
Hi again, glad to ear it.
Assuming you are using the styrbar blueprint you could turn on the settings for long press for the specific button you want to assign dimming to.
Then in the corresponding action add your light* controll
Wether or not you use transition like I do, some form of delay is recommended at the end
Another HA newbie here. A big thank you to the maintainer as I have successfully used the Blueprint and Light Hook to get this working with a Tradfri bulb and a STYRBAR E2002 Remote.
(RPi 3b I had already, ZHA).
A question - in a different room, I have 2 bulbs & a remote that are not YET connected to HA, but I have the single remote controlling both bulbs simultaneously. How can I use similar BP/Hook config to achieve what I have, now, but via HA? Can the Lights Hook control a Group containing 2 bulbs?
This fork is no longer being maintained and control has been given back to @EPMatt - 💡 (2025 Update: We are back!) Awesome HA Blueprints: A curated collection of blueprints for Home Assistant. Reliable, customizable, fully tested by the community - #117 by epmatt
For future support, please follow the link above.
Hi there and welcome - the hook can indeed control a group of lights.
Hope that helps.
