This blueprint supports the “TUYA Zigbee knob / scene switch” from AliExpress through the ZHA integration.
model: TS004F
manufacturer: _TZ3000_402vrq2i
blueprint:
name: ZHA - Tuya Smart Knob for lights - v1.1
description: 'Control lights with a Tuya Smart Knob from "_TZ3000_402vrq2i".
Tapping activates toggle event and will toggle the selected light.
Rotating left/right will change the brightness smoothly of the selected light.
Adjusted for generic Tuya Smart Knob, with functionality added for remote mode.
Device is switched to remote mode, and back, by rapidly tapping 3 times.
Once in remote mode the following functions are available
- Short Press
- Double Press
- Long Press
- Rotate Right
- Rotate Left
Based on
- Original blueprint by seamus65 (https://gist.github.com/seamus65/939a147634942dd885c8704334627f93).
- Improved by GonzaloAlbito (https://gist.github.com/gonzaloalbito/3dc06702e941e08298ea9bfade731731).
Version 2026-01-30.'
domain: automation
input:
remote:
description: Tuya Knob to use
selector:
device:
integration: zha
model: TS004F
multiple: false
light:
description: The light(s) to control
selector:
entity:
domain: light
step_percent:
description: Light percent change for each knob step
selector:
number:
mode: slider
min: 0
max: 100
unit_of_measurement: "%"
default: 20
short_press:
name: Remote Mode - Short Press
description: Action to run on single press
default: []
selector:
action: {}
double_press:
name: Remote Mode - Double Press
description: Action to run on double press
default: []
selector:
action: {}
long_press:
name: Remote Mode - Long Press
description: Action to run on long press
default: []
selector:
action: {}
remote_right:
name: Remote mode - Spin Right
description: Action to run on "right spin" in remote mode
default: []
selector:
action: {}
remote_left:
name: Remote mode - Spin Left
description: Action to run on "left spin" in remote mode
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- variables:
command: '{{ trigger.event.data.command }}'
mode: '{% if command == ''step'' %} {{ trigger.event.data.args[0] }} {% endif %}'
steps: '{% if command == ''step'' %} {{ (trigger.event.data.args[1] / 12.5 ) | int }} {% endif %}'
step_percent: !input step_percent
- choose:
- conditions:
- '{{ command == ''toggle'' }}'
sequence:
- service_template: light.toggle
target: !input light
- conditions:
- '{{ command == ''step'' }}'
- '{{ mode == ''StepMode.Up'' }}'
sequence:
- service_template: light.turn_on
data_template:
brightness_step_pct: '{{ step_percent * steps }}'
transition: 0.5
- conditions:
- '{{ mode == ''StepMode.Down'' }}'
sequence:
data_template:
brightness_step_pct: '-{{ step_percent * steps }}'
transition: 0.5
- conditions:
- '{{ command == ''remote_button_short_press'' }}'
sequence: !input short_press
- conditions:
- '{{ command == ''remote_button_double_press'' }}'
sequence: !input double_press
- conditions:
- '{{ command == ''remote_button_long_press'' }}'
sequence: !input long_press
- conditions:
- '{{ command == ''right'' }}'
sequence: !input remote_right
- conditions:
- '{{ command == ''left'' }}'
sequence: !input remote_left
