### The problem
I have a Waxman Zigbee water valve that is showing a "Water Val…ve Checkin event was fired" every few seconds non-stop. Others have similar problem with other devices. In my network this is the only device that has this problem.
### What version of Home Assistant Core has the issue?
2023.1.1
### What was the last working version of Home Assistant Core?
2023.1.1
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
ZHA
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/zha/
### Diagnostics information
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.1.1",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.7",
"docker": true,
"arch": "aarch64",
"timezone": "America/New_York",
"os_name": "Linux",
"os_version": "5.15.76-v8",
"supervisor": "2022.12.1",
"host_os": "Home Assistant OS 9.4",
"docker_version": "20.10.19",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"auto_backup": {
"version": "1.3.0",
"requirements": []
"hacs": {
"version": "1.29.0",
"requirements": [
"aiogithubapi>=22.10.1"
"localtuya": {
"version": "4.1.1",
"requirements": []
"midea_ac": {
"version": "0.2.3",
"requirements": [
"msmart==0.2.3",
"pycryptodome",
"pycryptodomex",
"click"
"solaredge_modbus": {
"version": "1.4.0",
"requirements": [
"pymodbus==1.5.2"
"nodered": {
"version": "1.1.2",
"requirements": []
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.34.5",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.90",
"zigpy-deconz==0.19.2",
"zigpy==0.52.3",
"zigpy-xbee==0.16.2",
"zigpy-zigate==0.10.3",
"zigpy-znp==0.9.2"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"dependencies": [
"file_upload"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 1835,
"manufacturer": "WAXMAN",
"model": "leakSMART Water Valve v2.10",
"name": "WAXMAN leakSMART Water Valve v2.10",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"manufacturer_code": 4411,
"power_source": "Battery or Unknown",
"lqi": 255,
"rssi": -40,
"last_seen": "2023-01-06T15:28:39",
"available": true,
"device_type": "EndDevice",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4411, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=0, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0002",
"in_clusters": [
"0x0000",
"0x0001",
"0x0003",
"0x0006",
"0x0020",
"0x0b02",
"0xfc02"
"out_clusters": [
"0x0019"
"active_coordinator": false,
"entities": [
"entity_id": "button.waxman_leaksmart_water_valve_v2_10_85a90f00_identify",
"entity_id": "sensor.waxman_leaksmart_water_valve_v2_10_power",
"entity_id": "switch.waxman_leaksmart_water_valve_v2_10_85a90f00_on_off",
"neighbors": [],
"routes": [],
"endpoint_names": [
"name": "ON_OFF_OUTPUT"
"user_given_name": "Water Valve",
"device_reg_id": "40bc61142d52256c38fd0982f67d7b9a",
"area_id": "garage",
"cluster_details": {
"1": {
"device_type": {
"name": "ON_OFF_OUTPUT",
"id": 2
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "WAXMAN"
"0x0005": {
"attribute_name": "model",
"value": "leakSMART Water Valve v2.10"
"unsupported_attributes": {}
"0x0001": {
"endpoint_attribute": "power",
"attributes": {
"0x0020": {
"attribute_name": "battery_voltage",
"value": 50
"0x0021": {
"attribute_name": "battery_percentage_remaining",
"value": 94
"0x0031": {
"attribute_name": "battery_size"
"0x0033": {
"attribute_name": "battery_quantity"
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {
"0x0000": {
"attribute_name": "on_off",
"value": 1
"0x4003": {
"attribute_name": "start_up_on_off"
"0x0020": {
"endpoint_attribute": "poll_control",
"attributes": {},
"0x0b02": {
"endpoint_attribute": "appliance_event",
"attributes": {},
"0xfc02": {
"endpoint_attribute": "manufacturer_specific",
"attributes": {},
"out_clusters": {
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
