Got a SMLIGHT SLZB06, connected via ethernet PoE. HA recopgnizes it, and installs the SLZB-06 Integration. I then try to install the ZHA,…
Logger: aiohttp.server
Source: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:451
First occurred: 5:13:12 PM (1 occurrences)
Last logged: 5:13:12 PM
Error handling request from 10.0.1.20
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/api.py", line 1114, in request_callback_rsp
return await callback_rsp
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/api.py", line 264, in start_network
commissioning_rsp = await self.request_callback_rsp(
...<9 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/api.py", line 1111, in request_callback_rsp
async with async_timeout.timeout(timeout):
File "/usr/local/lib/python3.13/site-packages/async_timeout/__init__.py", line 141, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.13/site-packages/async_timeout/__init__.py", line 228, in _do_exit
raise asyncio.TimeoutError
TimeoutError
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
return await handler(request)
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
return await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 121, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 340, in async_configure
result = await self._async_configure(flow_id, user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 383, in _async_configure
result = await self._async_handle_step(
flow, user_input["next_step_id"], None
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 490, in _async_handle_step
result: _FlowResultT = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 405, in async_step_form_initial_network
return await self.async_step_form_new_network(user_input)
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 411, in async_step_form_new_network
await self._radio_mgr.async_form_network()
File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 278, in async_form_network
await app.form_network()
File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 352, in form_network
await self.form_network(fast=True)
File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 405, in form_network
await self.backups.restore_backup(
...<7 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy/backups.py", line 171, in restore_backup
await self.app.write_network_info(
...<2 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/zigbee/application.py", line 171, in write_network_info
await self._znp.write_network_info(
network_info=network_info, node_info=node_info
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/api.py", line 400, in write_network_info
await self.start_network()
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/api.py", line 302, in start_network
raise zigpy.exceptions.FormationFailure(
...<4 lines>...
) from e
zigpy.exceptions.FormationFailure: Network formation refused: there is too much RF interference. Make sure your coordinator is on a USB 2.0 extension cable and away from any sources of interference, like USB 3.0 ports, SSDs, 2.4GHz routers, motherboards, etc.
Is the last item in the log…
really the issue?
