ZHA integration to do nightly backup of both Zigbee Coordinator adapter/dongle/stick and Zigbee network/database?
@all Hi everyone: any idea how this can be done on an HA raspberry based appliance? bellows depends on some crypto packages that need compilation. So even with a virtualenv to isolate the python packages this does not work on the Home Assistant OS installation.
Did somebody find a way to backup the Conbee II ? Following the instructions on Phoscon website by backing the zll.db file I get nowhere, I cannot find the file. Furthermore I am using ZHA and trying to load DeconZ only 3 devices show up …
zigpy developers are apparently working on deconz backup and there is a draft pull request for it here:
https://github.com/zigpy/zigpy-cli/pull/2
At least that is how I interpret answer from puddly when posted this feature request for zigpy-deconz:
https://github.com/zigpy/zigpy-deconz/issues/177
Started separate forum discussion thread on zigpy-deconz / zigpy-cli backup of ConBee/RaspBee here:
https://community.home-assistant.io/t/zha-libraries-will-soon-support-conbee-raspbee-backup-and-restore-that-can-be-used-for-zigbee-network-migrations/374782
Note! Understand that zigpy and the zigpy-deconz radio libraries which ZHA depends on are all free and open-source library with only volunteering developers working on them without pay so remember and you and anyone else are also are more than welcome to code the feature for it (the zigpy developers have so far been more than happy to help and other volenteering developers who are willing to step in to assist with helping to fix bugs or add features).
Off-topic, please either start a new separate discussion thread or reply to that existing thread instead:
https://community.home-assistant.io/t/backup-your-zha-husbzb-1-stick-and-even-seamlessly-migrate-to-a-new-stick-without-re-pairing/229044/
btw, know that puddly who develops zigpy-znp is planing to implement unified backup into zigpy-cli that will mean that once implemented you can use same backup command to backup all radio brands. See:
Tip! @le_top added possibility to backup your Zigbee network to a JSON file within Home Assistant by using “zha_custom” custom component by mdeweerd (originally fork of zha_custom by Adminiuga):
https://community.home-assistant.io/t/zha-custom-service-to-send-custom-zha-commands-extra-functions/373346
Mentioned “zha_custom” fork by @le_top has been renamed to “zha-toolkit” and moved to a new repository from mdeweerd on GitHub and a Blueprint make it a bit easier to achieve nightly backups:
https://community.home-assistant.io/t/daily-znp-zigbee-coordinator-backup-blueprint/377149
https://github.com/mdeweerd/zha-toolkit
https://github.com/mdeweerd/zha-toolkit/blob/dev/README.md#znp_backup-backup-znp-network-data
https://community.home-assistant.io/t/zha-toolkit-toolkit-service-providing-low-and-high-level-zigbee-commands-through-zha-zigpy/373346
I’m planning to migrate to a new coordinator. (I’ve ordered one of those Sonoff Zigbee 3.0 USB Dongle Plus devices.) I was trying to make a backup of my current coordinator. I’ve installed zha_toolkit. However, when I execute the following command:
service: zha_toolkit.execute
  command: znp_backup
I get this error:
'ControllerApplication' object has no attribute '_znp'
What’s going wrong here and how can I fix that?
See this:
znp_backup is for CC2xxx (TI) adapters, ezsp_backup for Silicon Labs based adapters.
Ah, that wasn’t mentioned in the readme. Are the backups compatible? In other words, can I restore my EZSP backup to my new CC2xxx stick?
2022-01-19 17:17:43 DEBUG (MainThread) [custom_components.zha_toolkit.utils] Parameters '{'command': 'ezsp_backup'}'
2022-01-19 17:17:43 DEBUG (MainThread) [custom_components.zha_toolkit] module is <module 'custom_components.zha_toolkit' from '/config/custom_components/zha_toolkit/__init__.py'>
2022-01-19 17:17:43 DEBUG (MainThread) [custom_components.zha_toolkit] event_data {'ieee_org': None, 'ieee': 'None', 'command': 'ezsp_backup', 'start_time': '2022-01-19T16:17:43.731062+00:00', 'errors': ['AttributeError("\'ControllerApplication\' object has no attribute \'_znp\'")'], 'params': {'cmd_id': None, 'endpoint_id': None, 'cluster_id': None, 'attr_id': None, 'attr_type': None, 'attr_val': None, 'min_interval': None, 'max_interval': None, 'reportable_change': None, 'dir': None, 'manf': None, 'tries': 1, 'expect_reply': True, 'args': [], 'state_id': None, 'state_attr': None, 'allow_create': False, 'event_success': None, 'event_fail': None, 'event_done': None, 'read_before_write': True, 'read_after_write': True, 'write_if_equal': False}, 'success': False}
2022-01-19 17:17:43 ERROR (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Error executing script. Unexpected error for call_service at pos 1: 'ControllerApplication' object has no attribute '_znp'
Well, ezsp_backup gives me exactly the same result… :thinking:
Maybe open an issue on his github ?
Done. It’s acutally the very first issue in the repo: Weird error · Issue #1 · mdeweerd/zha-toolkit · GitHub
It’s mentionned in the readme, but you can always suggest an improvement !
I prepared a more general backup command that will direct to the right backup procedure.
First of all, please respect that this specific thread is a feature request discussion and meant for support so please start a separate thread if asking for support/help and not discussing the feature request.
Understand that for support will need Zigbee Coordinator chip and firmware have today to migrate from.
As franscisp mentioned above; “znp_backup” (backup via zigpy-znp) is only for Texas Instruments Z-Stack / ZNP adapters/firmware, and “ezsp_backup” (backup via bellows) is for only Silicon Labs EZSP (Silabs EmberZNet Serial Protocol) adapters/firmware. There is as of yet no backup support for other types of Zigbee Coordinator like “deconz” (ConBee/RaspBee), “zigate” (ZiGate), or “xbee” (Digi XBee).
Both “znp_backup” and “ezsp_backup” save/restore using “Open ZigBee Coordinator Backup Format” which indeed means that you can backup a Silabs EZSP adapter and restore to TI ZNP or vice versa in order to use it as a migration method.
https://github.com/zigpy/open-coordinator-backup
The same Open ZigBee Coordinator Backup Format can obviously be used for migrating from older to newer adapter hardware/firmware with old respectively new chips from same chip manufacturer. Read:
https://github.com/zigpy/zigpy/wiki/Coordinator-Backup-and-Migration
I believe that Zigbee network + Zigbee Coordinator backups in the ZHA integration are also part of what Home Assistant founders indirectly thought about in new blog-post about “Streamlining Experiences”:
https://www.home-assistant.io/blog/2022/01/19/streamlining-experiences/
With Home Assistant the last few years we’ve been focusing on making things easier, stable, and faster. More things can be managed via the UI, most YAML-based integrations can be reloaded without restarting and if something breaks, safe mode and built-in backups have your back.
I really hope so.
I’m using the ZHA + ConBee2 setup and the single point of failure this poses is gnawing at the back of my head for a while now.
It does make me happy to see so much dedicated people working an an Esperanto version of the Zigbee network. This gives me the reassurance a decent option will be available in the near future.
Needless to say I upvoted this feature request!
Indeed. I was in the assumption I could just briefly disable ZHA, switch to zigbee2mqtt to test something, disable and stop that, enable ZHA again but… wrong!!!
No more working devices, everything needs to be re-paired again (opening up all those wall switches and build in devices etc.). I mean, the devices are still there and recognised in the integration, even if you delete it and add it again, but they keep greyed out and basically the network is just dead.
Home Assistant Core definitely needs this backup function build in. Even with the nice Home Assistant Blue (OS) Odroid nothing can go wrong or you can run around with your screwdriver (again) to copy/paste the right entity ID’s and walk trough all automations etc.
Became a bit reserved now expanding the Zigbee network on a regular base and will choose a strategy to wait until I have done all tests and with new devices that we want and then put it all in at some point and do not touch it ever again after. And pray the coordinator stick never dies.
Little extra’s could also be done with Z-Wave, that is way more stable with adding/excluding (though crazy expensive).
By the way, check out this new video at around 11 min 50 sec in where talk about and highlight this focus point about making it easier to start/setup common tasks and basic features in fewer steps, etc.
Hoping that this will peak the interest of more developers to help with more ZHA features, like backups.
FYI, zigpy-deconz (ZHA dependency library) in another zigpy library that will soon be capable of supporting ConBee/RaspBee backup and restore that can be used for Zigbee network backups and migrations, see → https://community.home-assistant.io/t/zha-libraries-will-soon-support-conbee-raspbee-backup-and-restore-that-can-be-used-for-zigbee-network-migrations/374782 and https://github.com/zigpy/zigpy-cli/pull/2
This requested feature will become more important when Home Assistant Yellow becomes available. I will have to transfer my Zigbee configuration information (currently using a ConBee II stick) to the Zigbee coordinator on Home Assistant Yellow.
