RESOLVED - BUT POSTING FOR ANYONE ELSE WITH ISSUE
Found a GitHub Issue with similar error: https://github.com/ethereum/eth-abi/issues/131
But apparently uninstalling of typing package as mentioned only works with pip 20.0.2 or lower…
So uninstalling typing, and downgrading pip to 20.0.2 resolved the issue.
I don’t know if there will be an issue I will have to resolve down the road… but my lights work again… and that’s really all that matters at the moment
After upgrading to 0.118 with Home Assistant Core in a Python (3.8) VENV… Ubuntu 20
Just started looking into it, but was hoping maybe it was something stupid/simple that someone has ran into before.
2020-11-18 15:55:58 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package zigpy-zigate==0.7.2: ERROR: Command errored out with exit status 1:
command: /srv/homeassistant/bin/python3.8 /srv/homeassistant/lib/python3.8/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-5qnbw_lp/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=30.3.0' wheel setuptools_scm
cwd: None
Complete output (42 lines):
File "/usr/local/lib/python3.8/runpy.py", line 192, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.8/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/srv/homeassistant/lib/python3.8/site-packages/pip/__main__.py", line 26, in <module>
sys.exit(_main())
File "/srv/homeassistant/lib/python3.8/site-packages/pip/_internal/cli/main.py", line 73, in main
command = create_command(cmd_name, isolated=("--isolated" in cmd_args))
File "/srv/homeassistant/lib/python3.8/site-packages/pip/_internal/commands/__init__.py", line 104, in create_command
module = importlib.import_module(module_path)
File "/usr/local/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/srv/homeassistant/lib/python3.8/site-packages/pip/_internal/commands/install.py", line 17, in <module>
from pip._internal.cli.req_command import RequirementCommand, with_cleanup
File "/srv/homeassistant/lib/python3.8/site-packages/pip/_internal/cli/req_command.py", line 16, in <module>
from pip._internal.index.collector import LinkCollector
File "/srv/homeassistant/lib/python3.8/site-packages/pip/_internal/index/collector.py", line 14, in <module>
from pip._vendor import html5lib, requests
File "/srv/homeassistant/lib/python3.8/site-packages/pip/_vendor/requests/__init__.py", line 125, in <module>
from . import utils
File "/srv/homeassistant/lib/python3.8/site-packages/pip/_vendor/requests/utils.py", line 25, in <module>
from . import certs
File "/srv/homeassistant/lib/python3.8/site-packages/pip/_vendor/requests/certs.py", line 15, in <module>
from pip._vendor.certifi import where
File "/srv/homeassistant/lib/python3.8/site-packages/pip/_vendor/certifi/__init__.py", line 1, in <module>
from .core import contents, where
File "/srv/homeassistant/lib/python3.8/site-packages/pip/_vendor/certifi/core.py", line 12, in <module>
from importlib.resources import path as get_path, read_text
File "/usr/local/lib/python3.8/importlib/resources.py", line 11, in <module>
from typing import Iterable, Iterator, Optional, Set, Union # noqa: F401
File "/srv/homeassistant/lib/python3.8/site-packages/typing.py", line 1357, in <module>
class Callable(extra=collections_abc.Callable, metaclass=CallableMeta):
File "/srv/homeassistant/lib/python3.8/site-packages/typing.py", line 1005, in __new__
self._abc_registry = extra._abc_registry
AttributeError: type object 'Callable' has no attribute '_abc_registry'
ERROR: Command errored out with exit status 1: /srv/homeassistant/bin/python3.8 /srv/homeassistant/lib/python3.8/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-5qnbw_lp/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=30.3.0' wheel setuptools_scm Check the logs for full command output.
WARNING: You are using pip version 20.2.3; however, version 20.2.4 is available.
You should consider upgrading via the '/srv/homeassistant/bin/python3.8 -m pip install --upgrade pip' command.
2020-11-18 15:55:58 ERROR (MainThread) [homeassistant.setup] Setup failed for zha: Requirements for zha not found: ['zigpy-zigate==0.7.2'].
