blueprint:
name: ZHA - Hue Dimmer v2
description: >
Controller for Philips Hue Dimmer Switch v2 (RWL022) via ZHA.
domain: automation
input:
remote:
name: Hue Dimmer Switch
description: Select the Philips Hue Dimmer v2 device.
selector:
device:
integration: zha
manufacturer: Signify Netherlands B.V.
model: RWL022
light:
description: The light(s) to control.
selector:
entity:
domain: light
# --- Configuration ---
dim_step:
description: Percentage to change brightness per loop cycle.
default: 10
selector:
number:
min: 1
max: 50
unit_of_measurement: "%"
dim_delay:
name: Dimming Speed (ms)
description: Delay between dimming steps.
default: 400
selector:
number:
min: 100
max: 1000
unit_of_measurement: "ms"
# --- Power Button (Top) ---
action_power_press:
name: Power - Single Press
default:
- service: light.toggle
target: !input light
selector:
action: {}
action_power_double:
name: Power - Double Press
default: []
selector:
action: {}
action_power_triple:
name: Power - Triple Press
default: []
selector:
action: {}
action_power_hold:
name: Power - Hold
default: []
selector:
action: {}
# --- Up Button ---
action_up_press:
name: Up - Single Press
default:
- service: light.turn_on
brightness_step_pct: !input dim_step
transition: 0.2
selector:
action: {}
action_up_double:
name: Up - Double Press
default: []
selector:
action: {}
action_up_triple:
name: Up - Triple Press
default: []
selector:
action: {}
# --- Down Button ---
action_down_press:
name: Down - Single Press
default:
brightness_step_pct: -!input dim_step
transition: 0.2
selector:
action: {}
action_down_double:
name: Down - Double Press
default: []
selector:
action: {}
action_down_triple:
name: Down - Triple Press
default: []
selector:
action: {}
# --- Hue Button (Bottom) ---
action_hue_press:
name: Hue Button - Single Press
default: []
selector:
action: {}
action_hue_double:
name: Hue Button - Double Press
default: []
selector:
action: {}
action_hue_triple:
name: Hue Button - Triple Press
default: []
selector:
action: {}
action_hue_hold:
name: Hue Button - Hold
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- variables:
command: "{{ trigger.event.data.command }}"
delay_ms: !input dim_delay
# Store device ID to use in wait_for_trigger without re-using !input
device_id: "{{ trigger.event.data.device_id }}"
- choose:
# --- POWER BUTTON ---
- conditions: "{{ command == 'on_short_release' }}"
sequence: !input action_power_press
- conditions: "{{ command == 'on_double_press' }}"
sequence: !input action_power_double
- conditions: "{{ command == 'on_triple_press' }}"
sequence: !input action_power_triple
- conditions: "{{ command == 'on_hold' }}"
sequence: !input action_power_hold
# --- UP BUTTON ---
- conditions: "{{ command == 'up_short_release' }}"
sequence: !input action_up_press
- conditions: "{{ command == 'up_double_press' }}"
sequence: !input action_up_double
- conditions: "{{ command == 'up_triple_press' }}"
sequence: !input action_up_triple
# SMOOTH DIMMING UP
- conditions: "{{ command == 'up_hold' }}"
sequence:
- repeat:
while:
- condition: template
value_template: "{{ repeat.index < 20 }}"
sequence:
brightness_step_pct: "{{ step_pct }}"
transition: "{{ delay_ms / 1000 }}"
- delay:
milliseconds: "{{ delay_ms }}"
- wait_for_trigger:
- platform: event
event_data:
device_id: "{{ device_id }}"
command: "up_short_release"
- platform: event
event_data:
command: "up_long_release"
timeout:
milliseconds: 50
continue_on_timeout: true
- if:
value_template: "{{ wait.trigger != none }}"
then:
- stop: "Button released"
# --- DOWN BUTTON ---
- conditions: "{{ command == 'down_short_release' }}"
sequence: !input action_down_press
- conditions: "{{ command == 'down_double_press' }}"
sequence: !input action_down_double
- conditions: "{{ command == 'down_triple_press' }}"
sequence: !input action_down_triple
# SMOOTH DIMMING DOWN
- conditions: "{{ command == 'down_hold' }}"
sequence:
- repeat:
while:
sequence:
brightness_step_pct: "-{{ step_pct }}"
- delay:
- wait_for_trigger:
- platform: event
event_data:
command: "down_short_release"
- platform: event
event_data:
command: "down_long_release"
timeout:
milliseconds: 50
- if:
then:
# --- HUE BUTTON ---
- conditions: "{{ command == 'off_short_release' }}"
sequence: !input action_hue_press
- conditions: "{{ command == 'off_double_press' }}"
sequence: !input action_hue_double
- conditions: "{{ command == 'off_triple_press' }}"
sequence: !input action_hue_triple
- conditions: "{{ command == 'off_hold' }}"
sequence: !input action_hue_hold
Hello jeff,
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
Note: if the original is in the forums here, it has to be in the top post in the topic and has to be the only code block there or the link will not work.
Hi I tested this but wasn’t able to get smooth dimming working. Maybe doing something wrong.
Does this deliver the smooth dimming you were after?
I found this to be best option Controller - Philips 929002398602 Hue Dimmer switch v2 | Awesome HA Blueprints
