ZHA quirks notes?
I have a handfull of Namron Zigbee devices. No firmware update available for these, OTA or otherwise.
The experienced problem (in my case) is that HA + ZHA does not appear to ‘hear’ the response from the ‘off’ command. HA will toggle the light a couple of times, and it will eventually remain off. And then I get a message in the HA UI:
The existing herdsman converter (for Z2M) is here:
ZHA does not appear to have a matching quirk at:
So, I wonder: does…
extend: [m.light({effect: false, configureReporting: true}), m.forcePowerSource({powerSource: “Mains (single phase)”})],
meta: {disableDefaultResponse: true},
… have equivalents in ZHA device handlers? Or ways to achieve the same result?
If (!) my very simplistic understanding of this holds any water, this has everything to do with setup of the device. Which tths://pypi_org/project/zha-quirks/ says we shouldn’t skip. (And then completely omits to say anything about. Unless my reading comprehension is off.)
Can I override these values in ZHA directly, perhaps? ‘configureReporting’ does sound a bit like ‘onOff | reporting_status’, for instance. Am I supposed to be able to change any of the bits the herdsman converter does, by writing valueX to attributeY of clusterZ in HA?
Any guidance is appreciated
