I’m working on a quirk for NodOn SIN-4-FP-21 pilot wire module (from discussion here.
This modulet is a kind of smart plug that can control a connected heating device through a dedicated wire (known as pilot wire).
The pilot_wire can set several levels : OFF, ECO, COMFORT, FROST_PROTECTION, COMFORT - 1°C, COMFORT - 2 °C.
As of today, I have a working solution (see link above), but the entity that is created for the “pilot_wire_mode” attribute is reported as “select.radiateur_sam_none”. I would like to have it reported as “select.radiateur_sam_pilotwiremode” or similar.
However, I haven’t found where I could define this suffix ? Any idea where I should start ?
Is it in the QuirkBuilder().enum() instruction ?
Is it in my CustomCluster class definition ?
Thanks for your help
